My front hurricane hinge for the roof hatch...
Postby Micro469 » Thu Aug 17, 2006 9:34 pm
I'm partial to the plastic hinge as well. No, I haven't got one but devinately considering it, maybe, kinda. I think you should give it a try at the front, it can always be changed at a later date.... :roll:
Steve, how long have you had your's on for? Got any closeup pictures??
O.K..... So I'm a slow typer.. :lol:
John
Micro469
Images: 382
Postby Dean in Eureka, CA » Thu Aug 17, 2006 9:47 pm
Steve,
You really got me thinking now... :?
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby jdarkoregon » Sat Aug 19, 2006 1:13 am
Steve, I'm interested too, is there any rating on life of the plastic/vinyl both if stored indoors or out?
John :designing:
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby RAYVILLIAN » Sat Aug 19, 2006 9:11 pm
Dean
The Warrior hinge has to be water tight both directions and water will leak back through that type of hinge when the hatch is up. The way I solved the problem was to put a 3/4 aluminum angle right up against the back of the hinge to act as a gutter. Work fine no leaks.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby mikeschn » Sat Aug 19, 2006 9:37 pm
Gary,
I am planning on using rubber over my hinge, like Endo did...
However, that plastic hinge has me wondering...
Images: 479
Postby Steve_Cox » Sat Aug 19, 2006 9:49 pm
jdarkoregon wrote:Steve, I'm interested too, is there any rating on life of the plastic/vinyl both if stored indoors or out?
John :designing:
John,
The hinge in question is made of polyolefin plastic. I have read manufacturer claims of 1,000,000 full travel cycles. But I'm sure that was with perfect alignment between the two hinged parts, not something that happens in the real world. I think a good question is how many times do you think you would raise the hatch on a tear drop in your lifetime? :lol:
I just happened to have a little piece of this hinge on a home made plastic bait bucket lid. It's been outside for about 8-9 months now, so far the UV hasn't affected the hinge, the bucket is getting a little brittle looking on top though.
Mike,
Endo's hinge w/cover looks like a pretty nice way to go on an aluminum skined trailer.
Steve_Cox
Images: 196
Postby Arne » Sun Aug 20, 2006 7:08 am
If the plastic hinge is installed on top, does it need to have metal strips over it to keep it flat? It would seem that it would need a lot of closely spaced screws to keep it from buckling..... interesting concept.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Arne » Sun Aug 20, 2006 7:18 am
Mike, is it worth the effort? You need hinges, rubber, aluminum strips to put it together....
What is the source of the rubber?
Arne
Mr. Subject Line
Images: 96
Postby mikeschn » Sun Aug 20, 2006 7:23 am
Arne,
What ever I choose has to be weathertight in both directions. A hurricane hinge is not. That's why the polyolefin plastic hinge sounds so interesting...
We got the rubber from a local roofing place. It was scrap from a job they did that day. They just gave it to me! Free!
Mike..
Images: 479
Postby Psychohillbilly » Sun Aug 20, 2006 2:47 pm
Just my two cents worth.
I used the hinge from So-Cal Teardrops for my galley hatch.
This hinge is water tight in both directions. It's expensive but I
am very happy with it.
Psychohillbilly
Psychohillbilly
Images: 5
Users browsing this forum: Google [Bot] and 7 guests
