doug hodder wrote:Have you tried drilling a pilot hole first? like 3/16 then follow up with the diameter you want....that should be fine for what ever thickness you are drilling...but once you've cooked the drill...it needs to be resharpened...don't throw them out...but there is a big difference in bit quality out there...Doug
Miriam C. wrote:Peggy
I used a titanium bit with a self starting tip ($11). Did all my holes with a Black and Decker cheapy drill. I drilled full power and Leaned into it.
Warning if you push too hard, and it cuts a big chunk it will lock and try to break your wrist. Have twelve holes.
Have fun
Rev. Ken wrote:Miriam C. wrote:Warning if you push too hard, and it cuts a big chunk it will lock and try to break your wrist. Have twelve holes.
And if it doesn't break your wrist it tears your tendon and that means surgery, (just got over that one) Be very careful drilling.
madjack wrote:hey Auntie M...I see y'all finally took those Ma and Pa Kettle "meetin' " clothes off and got a new avatar
Users browsing this forum: No registered users and 39 guests
