Has anyone used a 6 gallon propane hot water heater? How much propane do they use over a weekend? Is that why larger trailers always have twin propane tanks?
48Rob wrote:Hi
PS. I really like the standing pilot model, as the pilot alone keeps the water hot all night.
The burner only kicks on after a shower.
Jiminsav wrote:Rob, don't you need a shut-off valve before the big adaptor when you use a 1 lb bottle, seems to me the gas would blow through the open end of the big connection.
madjack wrote:Jiminsav wrote:Rob, don't you need a shut-off valve before the big adaptor when you use a 1 lb bottle, seems to me the gas would blow through the open end of the big connection.
...you wanna bet he leaves the big tank in place and shuts the main valve to it when using a 1# cannister...Ibetchabuddy
Users browsing this forum: philpom and 13 guests
