trimming off the vent fan interior piece?
Postby oklahomajewel » Tue Sep 26, 2006 8:17 am
I don't know what ya call it... that square 'ring' that slips in the vent fan opening, on the interior , to frame out the vent. Ya know, in the ceiling?
Well, it's hard plastic and I know it's mentioned before about having to trim it to fit. I do - about an inch.
What's the best/easiest way to cut it?
Thanks...
ps... building is moving along, taking pics but home computer is broke so I'll catch up later.
Julie
oklahomajewel
Images: 82
Postby sunny16 » Tue Sep 26, 2006 8:23 am
I remember trimming my trim ring but for the life of me I can't remember how or what I used. I think I just used the jig saw or the circular saw and ran it over using the bottom plate of the saw as a guide for width.
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby Gerdo » Tue Sep 26, 2006 8:47 am
I slid my "garnish" onto the fan, measured the space between the ceiling and the garnish. This measurement plus a little is what you want to cut off. I used a utility knife to score and bent the peice back and forth to break off. I think I used my tin snips to cut down the corners to the snap line. You could just use your snips if you wanted. This edge does go up inside the fan so it is hidden.
http://www.fantasticvent.com/faq/knowle ... stall.html
Gerdo
Images: 156
Postby bledsoe3 » Tue Sep 26, 2006 8:56 am
Julie, I used a utility knife. It doesn't cut easily. I just kept going over the same line and it eventually cut through.
bledsoe3
Images: 112
Postby doug hodder » Tue Sep 26, 2006 9:05 am
I used a jig saw...and it doesn't have to be pretty, cuz it's hidden...Doug
Postby oklahomajewel » Tue Sep 26, 2006 9:46 am
Gerdo wrote:I used a utility knife to score and bent the peice back and forth to break off. I think I used my tin snips to cut down the corners to the snap line. You could just use your snips if you wanted. This edge does go up inside the fan so it is hidden.
Psycho!!! that is exactly what I was thinking last night.... score the mark line real good with knife, snip at the corner and bend.
I'll try that tonite...
Thanks guys... you are DA BEST !!! :lips:
oklahomajewel
Images: 82
Postby Steve Frederick » Tue Sep 26, 2006 11:19 am
I used the Fantastic unit. Just trim it with a pair of tin-snips, or kitchen utility shears...Easier on the skin..Be careful w/that utility knife! Experience is the best, though sometimes painfull, teacher! :cry:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby BILLYL » Tue Sep 26, 2006 11:44 am
Julie-
And I got the scars to show for it. Tin snips will work - but be careful with that utility knife.
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby vairman » Tue Sep 26, 2006 12:26 pm
I used my die-grinder, and it cut it like butter, and i still have all my fingers... LOL
Greg
vairman
Images: 215
Postby Steve_Cox » Tue Sep 26, 2006 1:00 pm
Julie,
Anything but a utility knife. :lol: :lol:
I used a jig saw, cause it was handy.
Steve_Cox
Images: 196
Postby oklahomajewel » Tue Sep 26, 2006 1:04 pm
vairman wrote:I used my die-grinder, and it cut it like butter, and i still have all my fingers... LOL
Greg
I might try the friend's RotoZip... it cut thru the Formica like butta and did fine on the 1/8" mahogany too...
oklahomajewel
Images: 82
Postby kayakrguy » Wed Sep 27, 2006 10:32 am
Go with rotozip, even an angle grinder should do the trick....but as member of scar club I don't recommend the utility knive on hard, slippery surface...
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
