Hello, boardhead
I am not an expert when it comes to getting my hands in grease however,
I find that my experience is in finding data on this subject. Have talked to
a few who have taken various steps to become more acquainted in the
hands on effort that you seek information on while I try to find numbers for
maintenance issues related to bearings and grease.
It has become painfully apparent in my quest to that end that HF trailers
are made in sweat shops across the globe. Numbers ... well for some of
their rigs they choose not to list the stinking numbers. ugh~ Trust me with
email and phone in hand, along with Jack's AKA "The MadOne" admonition
about HF trailer bearing and seals ... I am getting the point brought home.
Now for and attempt to the short partial answer:
You got the only HF trailer that is touted here that HF gives you the part
numbers plain and clear on their web site. Good for you.
You will need TWO BEARINGS and TWO SEALS per wheel. If you did just
one you may have your result of the dreaded splatter d' grease.
Your trailer:
HF model 90154 ITEM 90154-8VGA HF
1175 LB. $239.0
HF CAPACITY 48" x 96" FOLDABLE UTILITY TRAILER WITH 12" WHEELS
http://www.harborfreight.com/cpi/ctaf/D ... mber=90154
Manual 90154
http://www.harborfreight.com/cpi/ctaf/m ... emID=90154
Harbor Freight Customer Service Representative
Monday-Friday 9:00 - 5:30 EST at 1-800-444-3353
1175 LB. $239.0
Bearing type .............................(28079 BEARING 25M 284 2.85)
Bearing part number..................
ITEM 93834-0VGA
Cost about................................$4.99
Need 2 Bearings per wheel 4 per trailer.
Bearing seal/cap.......................(27737 GREASE SEAL 229 1.00)
Bearing seal /cap part #............
ITEM 93833-0VGA
Cost about................................$2.99
Need 2 per trailer.
"Cliky"Here .... is a thread that some more
hands on experts talk of your trailer while having got grease on their hands
before. You will also note a link here that will show and tell the secrets of
grease in hand while holding cold bearings in a "Servicing Wheel Bearings"
Tutorial.
Good luck~
For those that want to know more about bearings or trailers that are touted
here .... go here:
T&TTT Forum Suggests 5 Trailers for New builds HERE~
