Jiminsav wrote:Nightcap, that looks spiffy, now, go along the outside and put a pocket hole and screw between the ones you have inside..the ones from inside out are just holding on the edge of the wood, you need some screws towards the interior of the floor.
Micro469 wrote:Jiminsav wrote:Nightcap, that looks spiffy, now, go along the outside and put a pocket hole and screw between the ones you have inside..the ones from inside out are just holding on the edge of the wood, you need some screws towards the interior of the floor.
Dang... If he does that he's got to take it all apart again.... Back to square one........
Miriam C. wrote:Nightcap,
With the metal frame going all the way around your trailer you won't really need outside screws. What you might consider is putting screws from the inside to the metal frame. Use self tapping and just drill away. Shouldn't take many and you will have your spars to keep it from coming in on you. jmho.
