Gerdo wrote:GFI breakers are expensive so that is why most houses have a GFI outlet be the first on a circuit that protects the whole circuit. My house, and probably yours, has a GFI outlet in one bathroom that feeds the an outlet outside and in my garage. 200' of wire instead of more GFI outlets.
Dale M. wrote:Well.......... IF..... If there is any chance AC voltage can come in contact with any metallic component of trailer, and if there is a chance you can come in contact with that metallic component and ground (earth) there is possible potential for electrocution.... GFI may prevent you from dying...
Dale
CHUCKLEHEAD69 wrote:IF U DONT HAVE WATER IN YOUR TRAILER IS IT REQUIRED FOR U TO HAVE GFCI'S, crap I'm not yelling sorry. don't most the campgrounds have gfci's at the pole. if it is required I'm thinking of gfci's breakers instead of outlets.thanks in advance
Users browsing this forum: No registered users and 32 guests
