Styrofoam and glue question
Postby Ken » Thu Dec 30, 2004 6:43 pm
I discovered today that panel adhesive (Liquid Nails) and styrofoam insulation don’t mix. I glued my first piece up and in a few minutes it fell of the wall. The panel adhesive dissolved the styrofome. I would like to glue both sides of the insulation to the inner and outer walls and ceiling for extra strength. Best idea I have come up with now is to spray carpenters glue. Anyone have any other ideas?
Ken
Keeper of the Green Key
Postby Joseph » Thu Dec 30, 2004 7:14 pm
I used PL Polyurethane Premium Construction Adhesive. Worked fine. :thumbsup:
Joseph
Joseph
Teardrop Pirate
Postby RAYVILLIAN » Thu Dec 30, 2004 9:01 pm
They make a non flamable contact cement. It is latex base but should work if you keep it dry. Should work in the walls where it ain't sapose to get wet anyway.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby darkroomsource » Fri Dec 31, 2004 4:07 am
Liquid nails makes a product that works with foam and wood, what are you using? The metal product?
-- Andy Hughes
My Teardrop
Grace Happens
darkroomsource
Postby beverlyt » Fri Dec 31, 2004 6:42 am
We didn't glue ours in. We just crammed in it there really tight and called it good.... :o
beverlyt
Images: 20
Postby Denny Unfried » Fri Dec 31, 2004 8:58 am
I used three layers of 1/2" polystyrene foam which bends easily. On the roof radius the layers were attached with hot melt glue till the hardboard was installed.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby SteveH » Fri Dec 31, 2004 9:28 am
I just got thru installing the insulation in my tear, the blue stuff from Lowe's, and I used two rattle cans of automotive contact cement for two layers of insulation. It worked OK, but not great, but it was easy. :)
SteveH
SteveH
Images: 42
Postby Ken » Fri Dec 31, 2004 5:35 pm
The automotive contact cement sounds like something I need to look into, thanks Steve
Ken
Postby mexican tear » Fri Dec 31, 2004 8:11 pm
I used the 3M spray adhesive. It is a little costly, but works great to hold the insolation in place, even on the radius.
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Postby Jiminsav » Sat Jan 01, 2005 10:27 pm
they make a product thats just for glueing styrene panels..it's made by liquid nails..kinda looks like thick glue, but it will stick to the styrene when it's dry.
Jim in Savannah
Jiminsav
Images: 40
Users browsing this forum: No registered users and 43 guests
