Okay, I was going to put the small window a/c on the interior cabin shelf, vent it for intake/exhaust out the side but hadn't come up with the drain pan stuff yet......
now I'm thinking I'll just keep it in the car, then place it under the door or under the galley at the campsite, and rig the duct work up to the side wall and have some vent inside to run the air in... does that make sense?
I know IndyCubby and or McTeardrops... someone else has done this.. What works best for creating the catch at the a/c vent to hook it to the duct to run into the TD ?
Is that as clear as mud? haha
AND do you just let it sit on the ground , maybe beside or under the trailer and then what do you do when you need to adjust it in the night, or turn it off? Mine doesn't have a remote, bought it new last year. But it does have built in thermostat and can do vent or cool.
julie
