Charging batteries while traveling
Postby madjack » Fri Mar 23, 2007 12:58 am
Gage wrote:I've got a question that I just happen to think of and goes along with this thread. What keeps a one wire alternator from over charging your battery? I have one wire alternators on both my '56 & '59. (the only chevy parts on those two)
...Gage, my guess would be the internal regulator in the alternator................................. 8)
Postby cuyeda » Fri Mar 23, 2007 1:42 am
I like the solenoid, and or diode additon. It seems simple enough, and have a few solenoid relays and diodes laying around.
Thanks Len19070!
Clive, I know who to ask when I need a circuit built for something.
dahoon, appreciate the offer for the research. I have a 1998 Dodge Ram truck 1500, but the solenoid relay suggestion may be more cost effective.
Now I know what the AUX center pin is for. I have a need to use back up light on one of my projects.
Cliff & Vanessa
cuyeda
Alternators & Battery isolator circuits
Postby sdtripper2 » Fri Mar 23, 2007 1:43 am
After a search I have some reading for those inclined to know more about
the alternator.
One wire Alternator:
http://www.alternatorparts.com/FAQ.htm#one%20wire
Frequent questions about Alternators:
Understanding Alternators:
http://www.alternatorparts.com/understa ... nators.htm
Alternators - what are they, how do they work and what breaks??
http://www.misterfixit.com/alterntr.htm
Battery Isolator theory:
This may be an interesting read for some?
Found an example of a dual battery system such as Tow V & Teardrop:
http://www.fridge-and-solar.net/dual_bat.htm
This is a two in one layout for those that might install an auxiliary battery
under the bonnet of their car and/or one in a caravan or camper trailer.
sdtripper2
Search Garoux
Images: 168
Postby dahoon » Sat Mar 24, 2007 2:00 am
A one wire alternator has an internal regulator built into it.
Please don't unhook the battery if you suspect that it or the battery is bad.
We have customers that do that and the alternator goes into a full-field charge since it senses no voltage on the line and it blows the diodes out of the rectifier.
Mike
dahoon
Images: 76
Postby Gage » Sat Mar 24, 2007 2:46 am
dahoon wrote:<snip>
Mike
So when working on the elect's and you unhook the battery to keep from the possibility of getting bit, this will hurt the alternator(possibility of blowing the diodes)?
Image Image Image
Gage
Images: 28
Postby dahoon » Sat Mar 24, 2007 3:15 am
Sorry Gage,
I meant to say while the engine is running and the alternator is operating. Not when the vehicle is shut off.
Mike
dahoon
Images: 76
Postby Gage » Sat Mar 24, 2007 3:24 am
Thanks Mike. You had me worried there for a minute. Because that's the first thing I do when working on one of my on going projects. :)
Image Image Image
Gage
Images: 28
Users browsing this forum: No registered users and 26 guests
