EZ wrote:Mary K, it sort of looks like you are trying to bend the trim in 2 dimensions if that makes sense, because you are doing the corner. I did "one dimension" like along the curve of the ceiling but just butted up agains the side wall. Does that make sense? It seems to me that is why the trim is twisting. Maybe you are just asking too much of it over a small radius.
I'm not sure I understand that but I know what I meant.
Ed
Miriam C. wrote::cry: Mary K try taking the wood trim to the shower with you. Kinda pre-bend by leaning on it some. Rather than a heat gun on the plastic a good hair dryer will probably work.
Did you try coving instead of quarter round? I need to know what not to get.
doug hodder wrote:Mary...on some of that 1/4 round material...what I've done in the past is to cut down a lot of the material on the back 90 degree...get rid of the squared off edge...the more material you get out of the trim the easier it will bend...also make sure you pick out really straight sticks...I make my own up from mohagany...dunno if any of this makes any sense...Doug
toypusher wrote:Here's a drawing of what Doug was talking about
Classic Finn wrote:toypusher wrote:Here's a drawing of what Doug was talking about
Ahhhh haaaaaa and it will bend after that procedure?
Classic Finn
