Relay Wiring?
Anything electric, AC or DC
Relay Wiring?
Postby Gerdo » Tue Jun 05, 2007 2:26 pm
I need to rewire my aux lights on my Tow Vehicle. I have a relay but I"m not sure of the wiring. Anyone able to help?
Gerdo
Images: 156
Postby dovaka » Tue Jun 05, 2007 2:32 pm
85 and 86 are your coil wires you need to run your input on one side and ground on the other 30 and 87 is the control wire you just need to splice in what ever it is that you want to control across those 2 and that is the switch for it
dovaka
Images: 6
Postby Gerdo » Tue Jun 05, 2007 4:00 pm
This http://www.classictruckshop.com/clubs/e ... glites.htm is showing things a little different.
Gerdo
Images: 156
Postby dovaka » Tue Jun 05, 2007 4:54 pm
that diagram is just how i said it except it is showing a 2 position relay which is 87a other then that it is the same i just might not be explaining it as well as a picture does
dovaka
Images: 6
Postby Dale M. » Tue Jun 05, 2007 5:42 pm
Gerdo wrote:This http://www.classictruckshop.com/clubs/e ... glites.htm is showing things a little different.
Yah!
Dale
Dale M.
Images: 18
Postby Elumia » Tue Jun 05, 2007 8:09 pm
this should help unravel the relay
http://www.6066gmcguy.org/BoschRelay.htm
Elumia
Images: 15
Postby Gerdo » Tue Jun 05, 2007 11:24 pm
Thanks. I will have no problem now. Thanks for the great fast replys. Problem solved.
Gerdo
Images: 156
Return to Electrical Secrets
