revamping the weekender
Postby dovaka » Tue Jun 05, 2007 1:00 pm
the wife and i have fallen in love with the weekender design and have decided to build one of them before we try making a benroy so i started tweaking around with the design a bit and so far this is what i have ended up with let me know what you think
p.s. i have been using google sketchup for a total of about an hour or so at this point so my skills in it are a little rough and this is the first thing i ever made in it
dovaka
Images: 6
Postby SaGR » Tue Jun 05, 2007 1:02 pm
Looks good to me! :thumbsup: :thumbsup:
Building a small bowtop Vardo
Build thread: http://tinyurl.com/yk4hnmd
Generic Benroy: Sold to FIL/MIL
SaGR
Images: 21
Postby Geron » Tue Jun 05, 2007 4:20 pm
Will it have any wheels on it?? :thinking: ;)
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby mikeschn » Tue Jun 05, 2007 4:28 pm
That's a good start...
Check this out for more ideas...
http://www.mikenchell.com/images/finalw ... kender.wrl
If you need cortona, go here... http://www.parallelgraphics.com/products/cortona/
Broadband is recommended... the wrl file is 15 megs...
Images: 479
Postby dovaka » Tue Jun 05, 2007 4:49 pm
Geron wrote:Will it have any wheels on it?? :thinking: ;)
g
no my plan is to save weight by having it be sled mounted
dovaka
Images: 6
Postby Miriam C. » Tue Jun 05, 2007 6:05 pm
Hey looks good to me. Just make sure your door isn't that close to the top.
Postby dovaka » Tue Jun 05, 2007 6:28 pm
Miriam C. wrote:Hey looks good to me. Just make sure your door isn't that close to the top.
yea i havent figured out how to round the edge of the box tool yet and i drew a base using the original measurements and i ended up shortening the flat top back 3" to make it 48" and that made the front angle drop down a few degrees making the door even worse
dovaka
Images: 6
Postby Miriam C. » Tue Jun 05, 2007 6:34 pm
Should be an easy enough fix. Just drop the door down and move it to the rear a couple of inches. :thumbsup: The other thing you can do is make the top panel longer Just need a little bit everywhere to give it more room.
Postby dovaka » Tue Jun 05, 2007 6:51 pm
few more tweaks
there is actually a frame on it but i didnt bother putting a pic of it up and i tried to draw a axle and my laptop is lucky it is still alive after that
dovaka
Images: 6
Postby SaGR » Tue Jun 05, 2007 7:46 pm
dovaka wrote:Image
So are the fold out counters going to scissor together when closed (i.e. overlap) or are the tops (surface) hinged to fold down?
I like it!
SaGR
Images: 21
Postby mikefowler » Tue Jun 05, 2007 8:12 pm
Heck I would go this direction and "Go with the flow!"
Maybe Mike can start a NEW forum - For "AIRDROPS"
:lol:
The Design Looks REALLY GREAT - All kidd'in aside
Aerodynamics are over rated!
I DRIVE A BOX!
Scion XB 2006 - 5 speed Manual
My continuing saga of 'As the TTT is built"
mikefowler
Images: 36
Postby Laredo » Tue Jun 05, 2007 8:19 pm
Okay, is that a 4x8 or a 5x9?
Laredo
Postby SaGR » Tue Jun 05, 2007 8:45 pm
mikefowler wrote:Heck I would go this direction and "Go with the flow!"
:lol:
:lol: :drofl: :lol: :drofl: :lol: :drofl: :lol:
SaGR
Images: 21
Postby volfanatic72 » Tue Jun 05, 2007 9:25 pm
I've been playing with the original design too...
Any negatives with making the front and rear angles the same???
volfanatic72
Images: 6
Postby dovaka » Tue Jun 05, 2007 10:59 pm
hmm that would lighten it up a bit using the balloon haha
not including the tongue box it is 65x114 end to end but the frame is only 65x110 including the tongue box it is 132 long
the counters are going to fold down and then the doors will shut i havent decided if im going to use 2 of them or just have one on one side
dovaka
Images: 6
Return to Member Designs
