has anyone had any luck with this, there was a thread a while back and it just seemed to die. I was wondering if its holding up. Mike did you use it?
It was teh garage two part epoxy
thanks
bob
Moderator: Sonetpro
Jeeper92 wrote:has anyone had any luck with this, there was a thread a while back and it just seemed to die. I was wondering if its holding up. Mike did you use it?
thanks
bob
jimqpublic wrote:We used an industrial grade 2 part epoxy floor paint in our garage about 7 years ago. It was a lot more than $20 a gallon- more like 60. You need to look at the "solids" percentage- the $20 paint is probably only partly Epoxy. The stuff we used was designed for indoor use- where it extends a few inches beyond the garage door it has faded a bit, but hasn't flaked or turned chalky.
