angib wrote:I came across this wiring diagram for the Scamp trailer and thought it might add to this thread:
The source page is here.
Andrew
TonyCooper wrote:1) 120VAC appears to use grounding from shore power. Is the consensus that ground should only be at the shore power plug and not trailer frame?
That gets my vote but I've seen references to grounding to the trailer(which to me seems dangerous).
2)I'm adding an inverter. The inverter has a chassis ground tab separate from the negative terminal. Should I simply ground this to the neg battery terminal (trailer chassis ground)? Somehow I don't think so... My instincts tell me this is for a true earth ground - a rod in the dirt! Any insights appreciated...
bdosborn wrote:
1) My opinion is that the trailer frame absolutely should be grounded to shore power. If for some reason the hot wire energizes the trailer frame, you want a path to conduct the current to ground (and pop the breaker). I don't want to be that path, which is what I would be if I touched it and the frame isn't grounded through the shore power ground. Since I'm a fairly high impedance path to ground, the breaker may not pop and the end result is barbeque Bruce. I may be tasty but I'm not that generous. So I'll ground the shore power plug(s) and the frame (as soon as I finish the stupid galley). If I were skinning with aluminum I'd ground that too.
2) I plan to ground the negative terminal of the battery to the chasis as well as the shore power ground. I don't want to have any voltage differences. And remember. the shore power ground does go to a rod in the dirt (or it's supposed to). The manufacturer of the inverter is counting on this, which is why they have a separate shore power equipment ground. Interestingly, a ground rod right at the trailer won't reduce the electrocution hazard. Here's an article about ground rods and touch voltage:
http://ecmweb.com/images/archive/0501btb.pdf
Here's some articles of what can happen with improper grounding:
http://ecmweb.com/mag/electric_electroc ... index.html
http://ecmweb.com/mag/electric_case_hot ... index.html
http://ecmweb.com/mag/electric_case_let ... index.html
TonyCooper wrote:Hi Bruce,
You may be right... I'm open for discussion... Lets walk through the logic...
For discussions sake lets assume no trailer circuit breakers or GFCIs are installed (insanity!) and the only ground available is an 8' rod in the ground from shore power.
<snip>
Regarding my Inverter
I am not real clear about the inverter tab ground.... shore power ground seems unlikely as it is used to provide 120VAC from a completely disconnected system running on 12VDC.
My instructions are not clear and that is why I asked. It clearly is a inverter chassis ground tab.
Any and all insight on anything here would be very much appreciated.
bdosborn wrote:
Tony,
If there's no circuit breaker, you're right it pretty much doesn't matter what you do. I assume that you will have a circuit breaker from the the shore power circuit because its always required by code to be there. The difference between grounding the trailer frame and not (with a circuit breaker) is how fast the circuit breaker will clear the fault. The circuit breaker will open within a second or two when the hot wire touches the frame if its grounded. The circuit breaker won't open on an ungrounded frame untill something completes the path to ground. This leaves the trailer frame energized untill someone touches it. Also, people are a high resistance path to ground so the circuit breaker may not see enough current to open, leaving the frame energized untill the next person touches it.
Circuit breakers and GFCI protection are important and I'm putting them in my trailer now. But, good grounding is important too in case you have a problem upstream of the GFCI.
I reviewed the NEC on trailers and it requires that the case of the inverter be grounded. I still think that's what the tab is for but I'd check with the manufacturer to make sure.
Thanks for the good discussion and I hope I helped,
TonyCooper wrote:Thanks for the clarification Bruce,
Couple more questions... in the case of a 120VAC short to trailer wouldn't the GCFI see the difference in voltage between neutral and hot, and trip?
With regards to grounding the inverter, not to show my stupidity here but ground it to what??? If I'm not plugged into shore power I can't ground it to shore power ground... Grounding it to the frame does nothing unless the battery neg is grounded to frame as well. And it that is the case why not just run a line directly to the battery neg terminal...
I stay in a perpetual state of confusion...
TonyCooper wrote:Thanks! I appreciate the time taken for the explanations... I've read and reread our dialog a few times and it's finally sinking in... Again, thanks for the help!
toypusher wrote:
Is there a CB for the AC side that can be used without a breaker box? I don't want to have to spend $70 or more for a breaker box to hold only one 20A CB. You gave me a link to Granger (I think it was), but I don't understand the breaker that it led me to. Or how to use it for that matter. I was hoping that there is some kind of 120VAC Circuit Breaker that can be used stand alone or in-line (like the 12VDC ones).
Kerry
Users browsing this forum: Google [Bot] and 10 guests
