bdosborn wrote:Guy wrote:Dear SteveH,
Could you spell that out for us dummies. Precisely how do you hook it up to the ignition? What wires go to what posts?
Attach a red #10 wire and a 30 amp in-line fuse to the + terminal of the battery. From the battery, the wire goes to the solenoid contactor (which will be labeled). Then the red wire goes from the solenoid contactor to the + terminal of the trailer battery (through the plug connecting it to the tow vehicle). There already should be a ground wire to the trailer for the stop/turn lights so you don't need to add another one if its there. Make sure you get a continuous duty solenoid. Starter solenoids are only rated for intermittant use and will fail prematuraly. Then find a wire in the car that is only hot when the key is on. Splice in a #12 wire from the key-on-hot wire to the coil of the solenoid. Make sure the coil is grounded and you're done. Clear as mud, right?
Here's a picture of a starter solenoid for an example. The wire from the batteries goes to the big terminals on the right and left. The key-on-hot wire goes to one of the little posts in the middle. A ground wire goes to the other little post in the middle. I can post a wiring diagram sketch if anyone wants one.
Users browsing this forum: No registered users and 45 guests
