Side running lights
Anything electric, AC or DC
Side running lights
Postby Reddiver » Sat May 31, 2008 3:49 pm
Well La Tortuga is moving along about ready to stack the bulkheads on the deck. My question is are side running lights required?
Reddiver
Images: 38
Postby Miriam C. » Sat May 31, 2008 4:03 pm
In most states side running lights are required on the front and back. Some states require blinker and stop light to be visible from the side too.
Postby Hinermad » Sat May 31, 2008 4:31 pm
I haven't found California's exact requirements online, but here's the federal Dept of Transportation requirement:
http://www.nhtsa.dot.gov/cars/rules/sta ... rpstr.html
This link is Cal. DMV's general guidelines for towing. There's a short section on lighting near the bottom but it doesn't go into details.
http://www.dmv.ca.gov/pubs/dl648/dl648pt12.htm
Here's the index for the section of the CA vehicle code that covers trailers. Check the links for reflectors, signal lamps, stoplamps, and tail lamps. There may be more. IANAL.
http://www.dmv.ca.gov/pubs/vctop/vc/vc_index_t.htm
Good luck!
Dave
Behind every successful man is a woman who wants a teardrop camper.
Hinermad
Images: 5
Postby Dale M. » Sat May 31, 2008 5:32 pm
California and most other states "require" at least the federal minimum standards.... Whether or not you follow this is your choice....
Here is most definitive requirement for clearance light..
http://www.dmv.ca.gov/pubs/vctop/d12/vc25100.htm
IF trailer is over 80 inch wide it IS required to have clearance lights...
Yes, 80 inches is trailers widest point probably at outside of fenders if so equipped.
Here is "alpha" index to CA DMV.... Probably easiest way to find anything...
http://www.dmv.ca.gov/pubs/vctop/vc/vc.htm
Dale
Dale M.
Images: 18
Postby emiller » Sat May 31, 2008 10:50 pm
I put 4' long running lights on mine because driving in California traffic at night drivers can't see my trailer and try to cut in right behind me and almost got hit a few times so I would recommend them. Plus backing in at night it gives kind of a refference of where I'm putting the trailer.
emiller
Images: 157
Postby Dale M. » Sun Jun 01, 2008 11:13 am
emiller wrote:I put 4' long running lights on mine because driving in California traffic at night drivers can't see my trailer and try to cut in right behind me and almost got hit a few times so I would recommend them. Plus backing in at night it gives kind of a refference of where I'm putting the trailer.
Good point.....
You should see surprised faces when people discover a empty car carrier trailer behind my truck... Even in daylight...
Dale
Dale M.
Images: 18
Postby wlooper89 » Sat Aug 09, 2008 3:50 am
I agree. The running lights might prevent someone from not seeing the trailer and hitting it. I know of one case where a Little Guy was hit by another vehicle and the trailer was sent back to the manufacturer for repair. I turn on my running lights day or night.
Bill
wlooper89
Images: 75
Return to Electrical Secrets
Users browsing this forum: Google [Bot] and 4 guests
