mikeschn wrote:Not bad.
I see you insist on knocking yourself out at night. That's fine.
I don't see any room for the roof. Spars are typically 1 1/2" and the skins are typically 1/8" on the inside and a couple layers of 1/8" on the outside.
I can't quite make out that gray thing by your feet. Is that an electric heater?
ScubbaStv wrote:Well I was hoping to have full support under the air conditioner so that there would be no sagging. If it is not going to be a problem, then that's a great idea. A full cabinet on th front would be nice but also add more weight and I am going to pull it with a 95 Jeep Wrangler with a 2.5 4 cyl, 5 speed. I also only have a 1.25" hitch receiver instead of 2". I'm trying to keep it as light as possible but have enough room... Kinda a catch 22 you know?
Return to Generic Building Plans
