BigWally wrote: my wife thinks I'm chatting to some hot mamma, for some reason she just doesn't believe I caruseing through this forms.
Lucky489 wrote:Is Kerry's schematic somewhere downloadable in a PDF. I can't seem to find it anywhere, but that is the way I want to wire my trailer. When I start.
Thanks
Mark
toypusher wrote:Lucky489 wrote:Is Kerry's schematic somewhere downloadable in a PDF. I can't seem to find it anywhere, but that is the way I want to wire my trailer. When I start.
Thanks
Mark
Just 'right click' on the image and 'Save Picture As..' and save it to your local computer.
Lucky489 wrote:Ah thanks I was thinking they were shruk, but it makes sense now.
reiltear wrote:2. Ditto what Dale said
3. The 12 gauge wire is rated 20A and 14 gauge 15A. What are you wiring? So, basically yes, you can use 12AWG instead of 14.
5. IMHO, the stranded wire would work better in this application - easier to feed through all the nooks and crannies in the TD and it should last longer for the same reason - it's more flexible.
toypusher wrote:Lucky489 wrote:Ah thanks I was thinking they were shruk, but it makes sense now.
I think that I might have some larger versions somewhere still. Which one exactly do you want??
Users browsing this forum: No registered users and 34 guests
