bobhenry wrote:The ac circuits all return to a grounding bar and the ground bar is hard wired to the shore ground only.
My running light return hard wired all the way back to the tow vehicles ground.
The on board 12v courtesy circuits return to a different grounding bar and from there directly wired to the on board battery negative post.
Bill my ac circuits are not grounded to the chassis they ground directly back to the shore power source ONLY. I have accidently shorter out wires while wiring a couple circuits hot and the GFCI that is the 1st load after entering my trailer tripped as well as the source gfiwlooper89 wrote:bobhenry wrote:The ac circuits all return to a grounding bar and the ground bar is hard wired to the shore ground only.
My D/C setup is the same as bobhenry's. I believe this means the trailer chasis has a D/C ground only when the tow vehicle is connected. The chasis of the tow vehicle would be connected to the trailer chasis, either by the wire connection or through the hitch itself. And normally then A/C shore power would be unplugged, unless the tow vehicle is left connected overnight.
Perhaps I should make my A/C setup like bobhenry's as well and connect A/C ground to the trailer chasis and shore power ground. I have GFCI protection but I wonder if the GFCI would even trip if there is a short to the trailer chasis with the chasis is not grounded to shore power. Maybe not until a person touches the chasis while standing on wet ground? Probably then the GFCI would trip after sensing the current running through the person to ground. I wonder how much of a shock that would be. Still confused.
Bill
bobhenry wrote: Bill my ac circuits are not grounded to the chassis they ground directly back to the shore power source ONLY. I have accidently shorter out wires while wiring a couple circuits hot and the GFCI that is the 1st load after entering my trailer tripped as well as the source gfi
Users browsing this forum: No registered users and 39 guests
