greasywheats wrote:Hey all- I picked up the Marinco charger inlet as well (rated at 15 amps.) I read somewhere else that if the campground has 20Amp service that you could fry the inlet. How probable is this? Do most CGs use 20 amp service? Should i run out an return this now? Ugh
Thanks!
Nytewyng wrote:Since my generic Teardrop from Littleguy didnt come with power, I havent "hacked " the camper yet. Trying to decide where the best place would be to have the shore line come into the camper. Any ideas? The Galley is very plain and will probably be used to keep stuff rather than cook in. My only plan so far, is power for a reading light in the cabin and probably one of those "power strips" so I can use a small fan or maybe watch a movie at night. I have a Littlguy 5x8
TomS wrote:This is what I used.
I got it from a local RV parts store. I simply pass my power cord through this hatch.
This view shows the hatch from the inside. It's simple and it works.
BPFox wrote:Here's a question for you. If you hook your trailer up to "shore" power, do you have to throw the trailer in the lake to make it work?
