Steve F wrote:...The battery (100AH fully sealed AGM) is in the galley under the bench with a marine switch panel to turn on the main sections of power. For something a little different the battery and panel are on a draw slide for easy access to the wiring...
brian_bp wrote:Steve F wrote:...The battery (100AH fully sealed AGM) is in the galley under the bench with a marine switch panel to turn on the main sections of power. For something a little different the battery and panel are on a draw slide for easy access to the wiring...
Very slick setup!
Not considering whether or not the wiring consequences of the moving panel might be a concern, the mounting setup is compact, accessible, and just clever.
Mary K wrote:All ya have to do is make a large loop of the wires and wrapped them this spiral wrap.
Very slick setup!
Users browsing this forum: Google [Bot] and 18 guests
