wlooper89 wrote:Oh, not at all. Ammeters are only necessary for those who dream them up late at night in their laboratories. As with the venerable Count, it is just an experiment. Perhaps ammeters could provide useful information, but who knows? So far I have not heard of one actually being used in a tiny trailer. Still, I am intrigued by the idea.
Bill
Dale M. wrote:I just have to wonder about the fascination with ammeter.... Yes it tells load value whether battery is in charge or discharge current flow mode.... But a volt meter will tell same thing whether it shows a voltage drop or increase....
Plus you can gauge time to failure with voltmeter.... Time to failure being the "curve" when battery voltage is going to drop below levels that which 12 volt appliances cease to function effectively...
Ironically most cars now actually have abandon ammeters and now have voltmeters...
Dale
Cliffmeister2000 wrote: I am looking for one that I can put between the trailer and the electrical supply just once to see the loads of the A/C, coffee pot, battery charger. That's all I have that is AC. Once I establish the loads, I should never need the meter again.
Dale M. wrote:...Ironically most cars now actually have abandon ammeters and now have voltmeters...
Dale
Cliffmeister2000 wrote:I think it would be more important for the AC side, when you are running appliances like A/C to know how close you are to maxing it out. I am looking for one that I can put between the trailer and the electrical supply just once to see the loads of the A/C, coffee pot, battery charger. That's all I have that is AC. Once I establish the loads, I should never need the meter again.
mechmagcn wrote:Cliffmeister2000 wrote: I am looking for one that I can put between the trailer and the electrical supply just once to see the loads of the A/C, coffee pot, battery charger. That's all I have that is AC. Once I establish the loads, I should never need the meter again.
If that is the goal, why not just get it all hooked up, turn everything on and use a clamp-on meter to check for the loaded amperage.
Dale M. wrote:For AC side, simply reading nomenclature tags on ac appliances and doing simple math you will know if breaker will hold under conditions where various items are plugged in.... Essentially its is same concept we use every day in our homes.....
Dale
