Slowing down a FantasticVent
Anything electric, AC or DC
Postby shoeman » Mon Aug 25, 2008 6:44 am
Well well well.... awesome research Aggie and Star!! Looks like I am not alone in thinking slower speeds would be beneficial. And now I do not have to call the factory for a fix. Heck, I can do this mod in a bout 10 minutes I bet. I'm going to my local electronics supply house today to get a resistor and put it in this afternoon.
We need to add this thread to the sdtripper list or make a sticky for it in the electrical section. I bet more folk will be interested in this mod.
:thumbsup: :thumbsup: :thumbsup: :applause:
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby jdarkoregon » Mon Aug 25, 2008 2:57 pm
Just in time, I came home from camping and using my fan for the first time (finally got it connected to the DC) and I thought it was noisier then I wanted it. But on low it really moved the air,
I'm thinking of doing this just to modify the productivity of the fan for the small size of the "coach"
Thanks for the thread
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Arne » Mon Aug 25, 2008 7:14 pm
since the fan has an off/on, how about replacing the 3 speed switch with a rheostat and forget about the resistor?
maybe buy one from the other company that uses it in their model?
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby shoeman » Mon Aug 25, 2008 7:50 pm
If you can find one rated for 10 watts it should be fine. I have not found one to that spec yet though.
I got a 5.1 ohm resistor today and spliced it in as directed in the tech bulletin and it seems to work fine. I'm going to try a slightly higher impedance and see if that is better yet. The 5.1 ohm is still a bit faster in the lowest setting than I'd like to have. I took some pictures of the install but left the camera in the garage tonight. I'll get it tomorrow and post them. It's a real simple mod to do and is easily reversible if you do not like the results.
shoeman
Images: 22
Postby shoeman » Tue Aug 26, 2008 7:51 am
Here is how I have it so far. You can see I used some spade connectors I had lying around that I crimped to the cut wire. The resistor leads push right into the female spade end. This will allow me to swap resistors easily until I get the fan speed I want. Once I get that settled I think I can simply crimp that one half of the spade and have a good solid hold on the resistor. I bent the leads to get the required offset from the fan support leg to hang it out in the airflow.
shoeman
Images: 22
Postby shoeman » Thu Aug 28, 2008 6:32 am
Tried a 10 ohm resistor yesterday and honestly I can't tell much of a difference between it and the 5 ohm. Both are a big improvement though for anyone looking to quite the hovercraft like sound of a stock Fantastic Fan in a little camper. Our next trip is a few weeks away so a field test will have to wait.
They cost me a buck each, so it's a cheap mod too.
Enjoy!
Geoff :thumbsup:
shoeman
Images: 22
Postby aggie79 » Thu Aug 28, 2008 8:18 am
Thanks Geoff for experimenting.
I saw the article but was hesitant to hack into my $140 investment. Looks like I'll give it a go when I get to that point of my build which at the rate that I'm (not) going that'll be late 2009.
For more on our Silver Beatle teardrop:
Images: 676
Postby Arne » Thu Aug 28, 2008 8:27 am
are the resistors available at radio shack?
The spades are a good idea... found one online.... 38 cents.... 9 dollars shipping..
Seems funny, but if I have to drive too far to find one, might as well get it delivered.... can buy a few different sizes....
Too many trips to the store (and they might not have what I want) and the shipping is cheaper..... what a weird world I live in.
Arne
Mr. Subject Line
Images: 96
Postby shoeman » Thu Aug 28, 2008 11:39 am
Arne wrote:are the resistors available at radio shack?
I'd bet they are sold at Radio Shack. I have a dedicated electronics parts store much closer to me so I did not try the Shack.
shoeman
Images: 22
Postby shoeman » Thu Aug 28, 2008 11:40 am
aggie79 wrote:Thanks Geoff for experimenting.
Go for it when you are ready. It's not a permanent mod and it requires no dis-assembly at all.
shoeman
Images: 22
Postby Toytaco2 » Thu Aug 28, 2008 5:34 pm
Ok Shoeman. It sounds and looks easy enough. I'm going to go for it as well. The resistor should be 4 ohms/10 watts. Correct? Is there anything special about the resistor or is this a standard type electronic item?
Thanks for checking this out as I think this will be a real improvement.
Toytaco2
Images: 367
Postby Mary K » Thu Aug 28, 2008 5:54 pm
Way to go!!! Sweet!! Thanks for the pictures and the details. I'll be doing this sometime before camping season. :thumbsup:
Mk
Mary K
Build Pictures
Mary K
6000 Club
6000 Club
Images: 47
Postby mikeschn » Thu Aug 28, 2008 5:57 pm
We are going to try that as soon as company goes home! :o :D
Images: 479
Postby jeep_bluetj » Thu Aug 28, 2008 6:35 pm
A PWM controller _would_ be superior. BUT a simple resistor is fine.
I just want to reiterate the "hang it out in the airflow" comment -- that resistor is going to get really quite hot - it's a ~6 watt electric heater. So don't let it stick to the plastic, etc.
In the airflow it'll be fine.
-- Jeff --
jeep_bluetj
Postby Gerdo » Thu Aug 28, 2008 8:28 pm
Sounds like my next project!
Gerdo
Images: 156
Return to Electrical Secrets
