Antique icebox
Antique icebox
Postby mikeschn » Sun Aug 01, 2004 9:30 am
Antique Icebox...
Isn't designing fun? :D
This morning I cut a hole in the counter top...
Then I dropped in a thermoelectric cooler unit
Then I figure I'll make the doors on the front look like an antique icebox
I don't know how many amps this draws yet, but I'll hook it up later today, and let you guys know what I find out.
Images: 479
Postby campadk » Sun Aug 01, 2004 9:34 am
Mmmmmmm... current!
My Koolatron draws 3.1A... which is why is has since been dumped in the 'garage sale' bin. Mike you'll have to add some more holes for a few extra batteries!! :wink:
campadk
Teardrop fun specialist
Images: 34
Postby mikeschn » Sun Aug 01, 2004 9:45 am
campadk wrote:Mmmmmmm... current!
Oh I know, that's my biggest concern... It would be nice to have 12v cooler that would last for a weekend, camping rustic. But the icebox could always use ice... I recall Sumner using both ice and 12v thermoelectric at the same time... Hmmmmmmmm...
P.S. I'm headed out to Bass Pro Shops now to do some more designing and playing!!! :D
Images: 479
Solar Panel sizes
Postby mikeschn » Sun Aug 01, 2004 11:58 am
Okay I just checked... it draws about 2.6 or 2.7 amps, or 64.8 amps every 24 hours.
To replace 65 amps a day with a solar panel I would need at least the 120 watt panel shown here... and 9 hours a day of charging time.
Not a real pretty situation. So going rustic really means ice. The only other option I can see is charging the battery with the tow vehicle every day.
I've attached here a chart of solar panels showing both watts and amps. Never can seem to find that when I need it... this is from the
http://www.oksolar.com/panels/solarex.html webpage...
MSX-120
MSX-120, 120Watts, 7.0 Amps
SX-85U
SX-85U, 85 Watts, 4.97 Amps
SX-80U
SX-80U, 80 Watts, 4.75 Amps
SX-75U
SX-75U, 75 Watts, 4.54 Amps
SX-65U
SX-65U, 65 Watts, 3.77 Amps
SX-65D
SX-65D, 55 Watts, 3.77 Amps
SX-60U
SX-60U, 60 Watts, 3.56 Amps
SX60-D
SX-60D, 60 Watts, 3.56 Amps
SX55-U
SX-55U, 55 Watts, 3.33 Amps
SX-55D
SX-55D, 55 Watts, 3.33 Amps
SX-50U
SX-50U, 50 Watts, 2.97 Amps
SX-50D
SX-50D, 50 Watts, 2.97 Amps
SX-50M
SX-50M, 50 Watts, 2.97 Amps
SX-40U
SX-40U, 40 Watts, 2.37 Amps
SX-40M
SX-40M, 40 Watts, 2.37 Amps
SX-40D
SX-40D, 40 Watts, 2.37 Amps
SX-30U
SX-30U, 30 Watts, 1.78 Amps
SX-30D
SX-30D, 30 Watts, 1.78 Amps
SX-30M
SX-30M, 30 Watts, 1.78 Amps
SX-20U
SX-20U, 20 Watts, 1.19 Amps
SX-20D
SX-20D, 20 Watts, 1.19 Amps
SX-20M
SX-20M, 20 Watts, 1.19 Amps
SX-10M
SX-10M, 10 Watts, .59 Amps
SX-5M
SX-5M, 5 Watts, .27 Amps
MSX-30L
MSX-30L, 30 Watts, 1.75 Amps
MSX-20L
MSX-20L, 20 Watts, 1.17 Amps
MSX-10L
MSX-10L, 10 Watts, .58 Amps
MSX-5L
MSX-5L, 5 Watts, .27 Amps
Images: 479
Postby campadk » Sun Aug 01, 2004 5:25 pm
My theory.... teardrop = KISS.
After debating this one for a good 6 months, we went with a cooler in the tow vehicle. Why not just buy a retro cooler? Or the Coleman stainless steel coolers which should blend into the theme.
Even a custom built in cooler, well insulated using just ice sounds like the plan. Since those 12V units only cool so many degrees below ambient temp, you many find the 12V unit actually melts any ice you have in the box :shock:
ice ice baby!
campadk
Images: 34
Postby mikeschn » Sun Aug 01, 2004 5:42 pm
Yep, I'm convinced. Ice is the way to go.
But I am tired of soggy stuff in my cooler. So would an icebox take care of the soggy factor, and still keep stuff cool enough?
Images: 479
Postby Spook » Sun Aug 01, 2004 7:29 pm
I have a spare frig that I use the freezer to keep frozen jugs of water in. The block ice last's 2 to 3 days in the N Georgia mountains. The good thing is minimum sog. My brothers use the ice for thier deer in the hunt season. Also if you make sure you have washed the previous liquid out well the water is drinkable when it melts.
Spook - Ball Ground, Georgia
Spook
Postby Larry Messaros » Mon Aug 02, 2004 1:35 am
mikeschn wrote:Yep, I'm convinced. Ice is the way to go.
What I plan to use (and what I had in my camper) is an actual RV ice box. The shelf was shaped to hold a block of ice and it had a drain hole in the bottom. A piece of tubing would run from the drain through the bottom of the ice box to the outside.
It was simple and worked very well. There was no case of the soggies and it always kept things cold enough.
Larry Messaros
:snow
Cariboo Country: If you don't like the weather, wait 5 minutes!
Larry Messaros
Postby Larry Messaros » Mon Aug 02, 2004 1:44 am
Spook wrote:I have a spare frig that I use the freezer to keep frozen jugs of water in. The block ice last's 2 to 3 days in the N Georgia mountains. The good thing is minimum sog. My brothers use the ice for thier deer in the hunt season. Also if you make sure you have washed the previous liquid out well the water is drinkable when it melts.
We use this method for our cooler when we travel on the weekends. We take 4 litre (1 gallon) milk jugs and rinse them out really well, fill them with water and then freeze them. We also use the 2 litre (1/2) gallon size plastic pop bottles for something a little stronger.
Larry Messaros
:snow
Larry Messaros
Return to Member Designs
Users browsing this forum: Google [Bot] and 3 guests
