Supersized grate...now with waffle!
Postby doug hodder » Sun Feb 01, 2009 4:34 pm
In an attempt to make my single burner 500 "waffle ready" I welded up a grate today. It's removable but since the original grate is tweaked a bit and welding pulled the small rod, the 2 aren't as compatible as they could be. I will need to install 2 small bolts with fender washers to sandwich the 2 together. Not fine tuned yet. I have a tall based waffle iron. It also accepts a 12 inch skillet. Not as nice as one person who favors blue equipment is building however. Doug
Postby rainjer » Sun Feb 01, 2009 4:44 pm
Very cool. It looks like we will be cooking waffles at the Dam Gathering on our 500 stoves. I am hoping to have my new grate done this week.
Jeremy
rainjer
King Koleman
Images: 11
Re: Supersized grate...
Postby Classic Finn » Sun Feb 01, 2009 6:57 pm
doug hodder wrote:In an attempt to make my single burner 500 "waffle ready" I welded up a grate today. It's removable but since the original grate is tweaked a bit and welding pulled the small rod, the 2 aren't as compatible as they could be. I will need to install 2 small bolts with fender washers to sandwich the 2 together. Not fine tuned yet. I have a tall based waffle iron. It also accepts a 12 inch skillet. Not as nice as one person who favors blue equipment is building however. Doug
Wow Nice Doug. :applause: :applause:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby cherokeegeorge » Sun Feb 01, 2009 7:51 pm
that looks sweet Doug :thumbsup:
George
For info on hitch covers
Teardrophitchcovers.com
cherokeegeorge
A Merkin Indian
Images: 37
Postby doug hodder » Sun Feb 08, 2009 1:24 pm
I cooked the first waffle on the grate and stove this AM. It really throws up a narrow column of heat...I'm finding it takes lots of turning to not burn the centers. All were edible so no waffles died an unnecessary death. At any rate....it works. Doug
Postby Juneaudave » Sun Feb 08, 2009 1:29 pm
Looks good to me!!!! Wonder if the stainless Jeremy plate would diffuse that a bit??? I want one!!!
:lol:
Juneaudave
Images: 380
Postby rainjer » Sun Feb 08, 2009 2:16 pm
Juneaudave wrote:Looks good to me!!!! Wonder if the stainless Jeremy plate would diffuse that a bit??? I want one!!!
:lol:
We will find out shortly.... I am off to make some waffles right now.
Jeremy
rainjer
King Koleman
Images: 11
Postby rainjer » Sun Feb 08, 2009 3:13 pm
Well here is the results!!!
I found that my wifes vintage ladle is the perfect size for my waffle iron. One scoop, one waffle. I may just need to find one to pint blue for the trailer... :twisted:
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Sun Feb 08, 2009 6:15 pm
Those waffles look really good...And I jest ate...... :thumbsup:
Seems like you both have the same problem... the center seems hotter. Any ideas on how to fix that? Perhaps a solid disk in the center to force the heat around it??? :thinking:
John
Micro469
Images: 382
