toypusher wrote:I have mine mounted as you have stated with the piece on the left mounted to the side of the tear and the flat side up.
Cliffmeister2000 wrote:toypusher wrote:I have mine mounted as you have stated with the piece on the left mounted to the side of the tear and the flat side up.
Hi, Kerry. Flat side up? So you fold the table down to remove it? I was thinking the rounded side up, and lifting the table to remove it.
See how easily I get confused?!?
Then the leg or legs hold the table in position. Great, Kerry, Thanks a bunch!
mikeschn wrote:The narrow piece gets mounted to the wall. The larger piece gets mounted to the table.
Then to install the table, you hold the table at about a 30 degree angle, set it on top on the small bracket, and then drop it down to horizontal.
Let me know if you need pics...
mikeschn wrote:The larger part definitely mounts on the table...
When I tried it the opposite way, I had to start with the table at 30 degrees below horizontal, and it never stayed up against the wall.
so this is the way to go...
