If your into bluegrass, cajon or blues music then this is somthing you should check out. It runs from oct. 6-9 in silk hope NC. Great music and really laid back crowd. Camping space is available. But let me warn you. If your the nervous and up tight type then this may not be the place for you. About as close to woodstock as you can get in this day. Wife and I went last spring and had a blast. check out the web site and hope to see you there.
http://www.grassrootsfest.org
