del wrote:Could be, we will see.Alan Wood wrote:Redneck awnings 101 sounds like a usefull course for us.
del
Man you and your dificult build quests.... Gotta build a standy one of these days. Maybe take Scotts weekender design and add a pop top.
del
This one??Miriam C. wrote::applause: Great idea. Now can I please get a picture of the bracket on top.
With my new wheels, the wider is the only way I can go, and not put in wheel wells.angib wrote:The rubber got in there by being frozen in liquid nitrogen, so you won't be able to cool the axle enough to get the rubber and spindles out.
You could cut the middle 13" out of the axle tube and then carefully weld and reinforce the centre joint, taking care not to 'cook' the rubber with the welding heat.
Andrew
I got that used from my uncle. When I priced it last winter (from Tom's rv near Tampa) it was $3 a foot, but here is the kicker I would have to buy the entire 20' stick. Call around, it is an awning track thingamabob.Jst83 wrote:Ok I not any help on the axle but I got a question on the awnings class.
Where did you get the track to slide the awning into?
