Hey! Where'd everybody go?
Haha, I don't know about everyone else but I went to bed, it was 1am!
You didn't say goodnight.
...I really want to see what it took to build that thing. brb.
del wrote:This getting dark at 9pm is slowing progress. All the wood has been cut into kindling, now to take it to the neighbors. A side line there is two placements of the large holes on th cross members. I am guessing a stamp/press bent them and punched out the large holes, then the smaller holes were drilled/punched out as needed.
del
I am just seeing what it would look like as a teardrop frame, cause I do not need another project. In other words having fun with the saws all.Alan Wood wrote:del wrote:This getting dark at 9pm is slowing progress. All the wood has been cut into kindling, now to take it to the neighbors. A side line there is two placements of the large holes on th cross members. I am guessing a stamp/press bent them and punched out the large holes, then the smaller holes were drilled/punched out as needed.
del
Del was the frame originally asymetrical like that or did you modify it?
Alan Wood wrote:I see. If you don't need it you really should consider donating it to a forum member on a they pick it up basis.
del wrote:Alan Wood wrote:I see. If you don't need it you really should consider donating it to a forum member on a they pick it up basis.
There I corrected it for you. Any way who wants a frame with no axle?
del
High Desert wrote:del wrote:Alan Wood wrote:I see. If you don't need it you really should consider donating it to a forum member on a they pick it up basis.
del
if I was closer del I'd take that frame off your hands. I have a good axle and tongue attached to a busted frame I need to rebuild. But alas, it is a frame too far...
Why is my transporter beam not ready yet?
del
I got 3 new wheels like this one.Alan Wood wrote:What's wrong with the Jelly Belly's axle?
del wrote:I got 3 new wheels like this one.Alan Wood wrote:What's wrong with the Jelly Belly's axle?
I need a wider axle, or bigger wheel wells.
del
When I buy the new drums I will take the old drum, and the new wheel (new to me) with me. First I need to pick up the wheels from behind my uncles garage in Kansas who I plan to visit right after ITG3.Alan Wood wrote:del wrote:I got 3 new wheels like this one.Alan Wood wrote:What's wrong with the Jelly Belly's axle?
del
Hm The only comment I have there is that it's not just 4 bolt versus 5 it's the spacing of the bolt holes.
