arnereil wrote:
About the weight of your trailer.... seems about 150 pounds too heavy... If it really weighs 400 pounds, I hope that is with the suspension and not just the frame.
And your wheel placement is determined by balance point, not by where you think it looks good.
angib wrote:I should add one more exception - if you know you want to bond something onto epoxy later, you can can cover it when wet with a 'peel ply' - a layer of woven nylon material. After the epoxy has cured, the peel ply is 'peeled' off (this can be hard work!) taking the amine blush surface with it.
Andrew
asianflava wrote:Thanks for the info, I thought the peel ply was to give it a rough surface to give it more "tooth".
mbader wrote:I took my unfinished tear on a week long trip from Calif. to Colorado.
I had 1 coat of epoxy sealer(Smiths A and B) on the wood. It rained nearly every day and there was no damage to the wood.
Roly Nelson wrote: Has anyone been there, done that?
