Dayum ...! Sure got lost in that site for a while ... been there for almost an hour ... ...! That last pic was the clincher, though ... ...!
Grant
Grant
Grant
I had to look twice!!!
The guy sitting in the trailer has an uncanny resemblance to someone
Regards
Ivar the Red wrote:So...you could tell me...but then you'd have to kill me? Is that it?
TopCat wrote:Thats looking like something workable? Im just wondering if you tow your trailer (once made) the revers from how its should be towed - Tail first. It will cut down on the wind resistance!
Looks like you have the planing done? When does construction begin
Regards
Regards
xrover wrote:What about buying or picking up a used tent and using the material from it for the sides and top? That would give you still a place that is dry, keep the weight way down, and since you don't have to take the tent down, you avoid one of the reasons we hate tents. Need lots of sealing!
In fact, you've given me a new idea. I have a 10" dobsonian telescope that I always have to cart out to an open area and it's a wee bit big. But using pvc and some bicycle tires............liking it! I would design it around a large garden cart.
the pvc bike guy wrote:OK so I'm cheating and getting a lot of help what do you think of this? ...
TheDuke wrote:Just an observation: Your PVC side rails could be a little twisty, and the axle mounts project out at the sides, leading to the wheels leaning in at the top. Maybe some kind of stiff axle running side to side? Really interesting concept, though. Worth doing more work on. There's probably a solution in there somewhere. Keep going.
TheDuke
grant whipp wrote:the pvc bike guy wrote:OK so I'm cheating and getting a lot of help what do you think of this? ...
That's quite the concept! And, it's looking pretty cool, too ... ...!
Would you allow me to suggest that you lower the side door opening to just above the pvc side rail, and maybe enlarge it to make entering & exiting much easier ...?
I'd be willing to bet that you could get that shape out of 1/2" pvc pipe, and by using the same for a few cross-braces, you could "skin" the entire outside with choroplast and have a really light & water-tight trailer! Grist for the mill ... ...?
Best of luck with it! In th emeantime ...
CHEERS!
Grant
Return to Bicycle Travel Trailers
