Cutterpup wrote:The only problem that I can see and its only because I am not color blind (like me son) is that you used the same color wire. The electricity doesn't care what color the wire is but (and I dought that you ever will) have a problem tracing the wire will be just a bit harder.
Dan
cracker39 wrote:Steve,
Is the lolwer box a fuse panel for the 115VAC stuff? If so, where did you get it and what type of fueses does it use? It's a lot smaller than the house type breaker box circuit breakers I was going to use.
cracker39 wrote:See, they did it again!!!
