What are you using for a frame?
What or whose frame do you use?
Harbor Freight
35
24%
Red Trailer
5
3%
Northern Equipment
4
3%
Custom, had it built
15
10%
Built it myself.
41
29%
Cannabalized an existing trailer and modified it.
41
29%
tractor supply
2
1%
Total votes : 143
Postby doug hodder » Tue Aug 18, 2009 10:11 pm
Recently in another thread the comment was made that "most builders are using either an HF frame or a Northern Equip." frame. I searched back to 05 in the polls and didn't see this one ever polled. It might be interesting to see what the results are. Unfortunately, it depends on the number of current active posting members...but what the heck....let's see how it all shakes out. Doug
Postby Juneaudave » Tue Aug 18, 2009 10:23 pm
Homebuilt...but maybe a stretch given my farmboy welding skills. Regardless, I enjoyed fussing with building a frame and nothing has cracked, bent, fallen off, or exploded....yet!!!
:oops: :roll: :roll: :roll:
Juneaudave
Images: 380
Postby doug hodder » Tue Aug 18, 2009 11:57 pm
Dave....as 1 "farmboy" to another....ya dun gud!....
Postby madjack » Wed Aug 19, 2009 12:02 am
I'm not much of a weldor so I just cut up the steel, get it jigged and then have one of my friends(who is a good weldor) come over and knock it out in half a day and then it's on to Miller Time(or some version or other)
madjack 8)
Postby grant whipp » Wed Aug 19, 2009 2:50 am
While I'll admit that Harbor Freight, Red Trailers, Northern Tools, and other similar trailers have been a boon to the home-built teardrop community, I will always put my teardrops and other trailers on custom-built chassis. Nothing will ever beat the longevity, safety, & security of a quality, purpose-built, to-your-specs, welded-steel frame (unless you get a lousy paint job on it and allow it to rust all to hell ... but, then, that's why I powder-coat 'em, too) ... IMHO ... :thumbsup: ...!
Bottom line, though, really, is to build the best you can afford and to the best of your abilities, keeping safety foremost in your mind, and you can always be justifiably proud of your efforts ... :applause: ...!
Get 'em Rollin', and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby len19070 » Wed Aug 19, 2009 3:46 am
On my Basic trailer "The Bare Bones" I use a Customer supplied Tractor Supply 4X8.
But for every thing else I fabricate my own.
Happy Trails
Len
len19070
Images: 24
Postby planovet » Wed Aug 19, 2009 8:46 am
Custom built here. I wanted something a little more solid than a bolt up and I have no steel working or welding skills at all.
http://www.diamondctrailers.com/
ImageMark (& Cindi)
planovet
The Cat Man
Postby halfdome, Danny » Wed Aug 19, 2009 8:52 am
My first one was custom built by a trailer manufacturer. The rest I custom welded myself, the best way to go in my opinion. Doug & Rich have a Trailer Frame Tutorial at the top of the page for those who may want to build their own. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Shadow Catcher » Wed Aug 19, 2009 9:20 am
Ours is the Mega-Mini and it is all aluminum, trailer and framing. The aluminum was one of the things I was looking at when contemplating building a tear my self. And looking at manufacturers, I was serousluy considering a Wazat, (aluminum frame)
I had found a number of of makers that could have built an aluminum trailer, (horse and boat)
This use of aluminum is the prime reason that while the MM has more features and is far larger than virtually all of the tears I have seen. It is as lite as it is, dimensions are 6' by 11' (14' over all)and is 1170 Lbs
The urge to make it HEAVY duty seems to overcome most builders, with out necessarily making it any stronger. The side walls and floor are part of the structure and add strength as long as they are fastened properly.
Postby asianflava » Wed Aug 19, 2009 1:28 pm
I cut the tubes and laid them out on the floor. Then my buddy welded them together. So, I built it, but I didn't weld it.
asianflava
Postby Wolfgang92025 » Wed Aug 19, 2009 1:36 pm
Same as above.
I cut and set out the frame. My Neighbor welded it for me. :thumbsup:
Wolfgang
Wolfgang
Wolfgang92025
Images: 651
Postby caseydog » Wed Aug 19, 2009 2:20 pm
My frame started life as a 1971 Dilly boat trailer. Spinnernut helped me cut it up and weld it together for it's second life as a TD frame.
My build journal is HERE
caseydog
Images: 515
Postby caseydog » Wed Aug 19, 2009 2:27 pm
Len, I seriously considered that Tractor Supply frame. It seemed to be a pretty good base for a lightweight TD.
Hey SnoopDoug, can you add that to the Poll choices? :thinking:
CD
caseydog
Images: 515
Postby Miriam C. » Wed Aug 19, 2009 4:14 pm
Got mine from my brother. Cleaned it up, straightened it out- - - mostly, and the rest is almost history.......... :D
When I do another it will be custom for the purpose. :thumbsup:
Postby chorizon » Wed Aug 19, 2009 5:27 pm
asianflava wrote:I cut the tubes and laid them out on the floor. Then my buddy welded them together. So, I built it, but I didn't weld it.
That's what I did!
chorizon
Images: 94
Return to User Polls
