clarkbre wrote:If I'm reading your question correctly, you want to know if running a certain tire pressure will do something good or bad for the trailer...Absolutely!
The way your finished, loaded trailer rides is directly effected by what tire pressure you're running. Running a very low air pressure will make the trailer more likely to wiggle and sway behind the tow vehicle. It will seem very bouncy and squishy and wear the tires on the outer edges. If a high PSI is used, the trailer will ride very harsh. Hitting bumps will make the trailer want to jump. The tires will also be over inflated and wear in the middle.
For even wear and a pleasant ride, there is an optimum PSI.
If you know the weight of your trailer loaded and ready, you're half way there. Take your trailer for example: GTW 1000. If balanced correctly, the tongue should have a weight of 100# and each tire should share the rest of the load at 450# each.
Lets say your trailer has 4.80-12 tires rated at a max load of 750# at 60psi. If you take your trailer weight knowing that only 450# is going to be riding on each tire, it's just a simple math formula.
Take your load per tire (450#), multiplied by the max PSI of the tire (60), divide that by the max load of the tire (750), and you get what should be your correct PSI for maximum ride and wear quality.
450x60= 27000/750= 36PSI
So, in this case, your trailer will perform best with a tire pressure right around 36PSI.
This formula can be applied for any tire as long as you know the max weight, PSI, and the actual weight it will be carrying.
Hope this helps.
Creamcracker wrote:
I understand the math (no problem) but it's stated in the HF manual that the tires must be inflated to 60psi.....there is no mention of changing the pressure to reflect the load....there have been instances of individuals on this board who have had tires disintegrate when they run them at less than 60psi......
Philip
Philip
The HF manual may say 60psi; however, it says that so when the trailer is fully loaded and the manufacturers GTW is at its maximum you dont have a tire blow out.
Our camping trailers are completely different beasts. For the most part the builder knows close to the final weight, balance, and gear load of the trailer. Adjusting tire pressure, axle location, and tongue length are all part of building and "tuning" the trailer to fit our needs. I guarantee your HF manual doesn't advise moving the axle position and/or altering the frame but it's a very common practice here on this board.
I have a Redtrailers utility trailer (almost identical to HF) and always run a tire pressure of 50psi. It rides like crap when it's empty but when it's got a weighted load it rides very nice.
In the cases where tires have disintegrated, it's easy for someone to blame it on tire pressure...it's the easiest way out. But, in the end, there are always factors that lead to operator error.
I would question everything relating to a tire blowout:
Was the trailer loaded, weighed, and tire pressure calculated?
When was the last time the tire pressure was properly checked?
How many miles were on those tires?
Were the tires rotted or cracked from sitting out in the weather?
What speed was it going when they came unglued? Some trailer tires have a 55mph limit.
"Nope, it was just tire pressure!"...Then why wasn't it addressed before the operator hit the road?
Creamcracker wrote:clarkbre wrote:If I'm reading your question correctly, you want to know if running a certain tire pressure will do something good or bad for the trailer...Absolutely!
Hope this helps.
Philip
