New off road build
Moderator: Sonetpro
New off road build
Postby jamscal » Wed Sep 23, 2009 7:34 pm
Hello all.
I've lurked for quite awhile but recently started my build.
I am a welder/fabricator and will be working in steel.
This is going to be a military inspired build...olive drab, some tank slit windows and other military vehicle details.
Axle is a 3000lb and I welded some mounts to make it spring over.
Jeep wheels came from the junkyard.
I used receiver tubing to bolt the hitch to. I did this to use a lunette or other off-road hitch in the future. ( I will be reinforcing the tongue area)
Trailer is 4x8. I angled the walls out and they're 5' wide.
I'm going to keep the square back, and have the kitchen door open to the side.
Thanks for looking.
jamscal
Postby Juneaudave » Wed Sep 23, 2009 8:27 pm
Nice work and nice start!!!! Can't wait to see how it progresses. Keep the pics coming!
Juneaudave
Images: 380
Postby jamscal » Fri Sep 25, 2009 8:08 pm
Thanks!
Here's a few more pics.
I bought a jack and some misc trailer stuff at Tractor Supply.
This thing is 23" off the ground so I had to make a bracket to 'lower' the jack.
I plan on cutting off the plate and installing a caster somewhere down the road as well.
Finally, I got a few more tubes installed, almost all of the in the roof and not visible in the pic. ..
Thanks for looking.
-James
jamscal
Postby jamscal » Sat Sep 26, 2009 9:11 pm
I couldn't find an olive drab color and my Paint skills aren't the best, but this is basically what I'm going for:
jamscal
Postby Endo » Sat Sep 26, 2009 9:29 pm
I like the shape!
I will be following your progress as well.
Have fun with the build and keep the pictures coming.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby jplock » Sun Sep 27, 2009 8:00 am
That is sure is a pretty welding on that frame! Looks Great!
jplock
Keep smiling!
jplock
Images: 233
Postby Carter » Sun Sep 27, 2009 9:15 am
2nd on the welding, I'm jealous. Nice design. As it says below, different is good.
Jim
I need a new Avatar. I'd put my dog up there but she doesn't look much like me. She's the skinny one.
Carter
Images: 32
Postby jamscal » Mon Sep 28, 2009 4:13 pm
Thanks guys.
I'm waiting on some tubes/ angle and a quote on my sheet.
I did have enough to skin the rear, which is sort of an experiment.
Mocked up the lights as well.
-James
jamscal
Postby jamscal » Fri Oct 02, 2009 4:14 pm
Got some more bracing in, both on the tongue and a few more cross bars.
Sheet metal will be here next Wed.
-James
jamscal
Postby wlivesey » Sat Oct 03, 2009 6:58 am
Thats a really nice looking off-roader. How are you going to layout the interior?
wlivesey
Images: 283
Postby jamscal » Sun Oct 04, 2009 2:31 pm
Thanks.
It looks like I'll have just a wall in the back to separate the sleeping area from the galley. Other than that, I haven't thought about it much :thinking:
Some other details, ideas:
Frame tubing is 2" 11ga. Body tubing is 1" 16ga..
A local salvage place has some engineered cork flooring. I may buy some of that for the floor.
I think it weighs a bit over 400lbs right now, according to my 400lb capacity digital shipping scale.
-James
jamscal
Postby jamscal » Fri Oct 09, 2009 9:05 pm
More pics. I have it skinned now.
Thanks,
James
jamscal
Postby Ageless » Fri Oct 09, 2009 11:14 pm
Heavy metal . . .I'm liking this!
Ageless
Postby bve » Fri Oct 09, 2009 11:15 pm
Nice!
So are you planning gull wing doors or what? That looks like it will be tough to do traditional side hinges with the walls the walls bend under.
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby jamscal » Sat Oct 10, 2009 10:40 am
bve wrote:Nice!
I'm going for traditional doors, but agree it will be tough. I'll have to get the clearances right and pay attn. to the weatherstripping.
The 'boatside' look, which I love, has presented several problems like that.
I'm sure I'll have several more.
-James
jamscal
