4x8 ----> 5x10 ?
4x8 ----> 5x10 ?
Postby tianac2 » Fri Jul 10, 2009 6:53 pm
I realize that this is probably a somewhat ridiculous question, but can a 5x10 teardrop be built on a 4x8 frame? Why?
tianac2
Re: 4x8 ----> 5x10 ?
Postby Steve_Cox » Fri Jul 10, 2009 10:57 pm
tianac2 wrote:I realize that this is probably a somewhat ridiculous question, but can a 5x10 teardrop be built on a 4x8 frame? Why?
1. yes
2. why not?
Steve_Cox
Images: 196
Postby tianac2 » Fri Jul 10, 2009 11:03 pm
1. yes
2. why not?
:lol:
Fair enough. Alright, then, HOW would one go about doing that? Raise the frame? Build the deck out over the wheels? Is it possible to do it without building over the wheels?
tianac2
Postby 2bits » Sat Jul 11, 2009 11:43 am
Replace the axle with a wider one if you don't want to build out over it, otherwise you would need to build over the axle. as far the the floor goes, just build the floor bigger than the trailer and let it over hang a tad , no biggie!
Thomas
2bits
2bit Member
Postby tianac2 » Sat Jul 11, 2009 2:38 pm
2bits wrote:Replace the axle with a wider one if you don't want to build out over it, otherwise you would need to build over the axle. as far the the floor goes, just build the floor bigger than the trailer and let it over hang a tad , no biggie!
Awesome! That's exactly what I needed to know....Thanks!
tianac2
Postby mikeschn » Sat Jul 11, 2009 7:53 pm
It's easy enough to build out over the wheels. If you use a harbor freight chassis, your teardrop will probably be closer to 66" wide. See my Escape Hatch to see how I did it... http://www.mikenchell.com/WWEH_Photo_Album/
Stretching it to 10' is a little bit tougher. It really helps if you can start with a 4x10 trailer chassis.
One of the things you have to be concerned about is that you don't build a larger floor on a smaller chassis, and end up with the trampoline effect.
Images: 479
Postby Tommy2tone_1999 » Tue Dec 29, 2009 10:37 pm
Hey Mike,
Kaspersky Internet Security flagged the web address you gave as:
The requested object is INFECTED with the following viruses: HEUR:Trojan.Script.Iframer
Hope this helps.
Tommy
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby bobhenry » Wed Dec 30, 2009 3:21 am
YEP!
out to out 5'7" wide 10' 3" nose to tail
If you are using a H.F. Frame I strongly suggest you use "Nobodys" method of reinforcing the tongue. There are pics in my album of Harvey's repair.
Images: 2617
Postby DMcCam » Thu Jan 07, 2010 8:19 pm
What about building a 4 x 10 on a 4 x 8 trailer? Can it be done without a lot of reworking?
Dave
DMcCam
Postby Steve_Cox » Tue Jan 19, 2010 7:21 am
DMcCam wrote:What about building a 4 x 10 on a 4 x 8 trailer? Can it be done without a lot of reworking?
Dave
Not too much rework on this one. 2 of the cross members used in the sides to extend them and the axle moved back. Had to drill a few holes. Actual frame length 117", 2X4 on each end during the build brought the length to 10 feet.
Steve_Cox
Images: 196
Postby bobhenry » Tue Jan 19, 2010 7:52 am
Here is a 5x10 on a 5x8 trailer I simply cantalievered the front 2' and extended the tongue.
It would be even easier to cantaliver 1 foot to the front and 1 foot to the rear. This may make a tongue modification unnecessary depending on the trailer
Images: 2617
Postby starleen2 » Tue Jan 19, 2010 8:40 am
The Ladybug is 6 X10 on a 4X8 TSC frame with no under framing beyond the trailer itself 8). We just cut off the fenders and built over the wheels
starleen2
5th Teardrop Club
Postby wannabefree » Tue Jan 19, 2010 9:00 pm
My 5x10, on a 4x8 HF frame:
The front and back actually only overhang the trailer frame by a few inches at the bottom. A foot or so up, though, they overhang a foot. No reason I couldn't have dropped straight down and gotten more length at the bottom; I just liked the curves.
The floor is built on a 4 inch thick torsion box that extends out over the wheels. The 4 inches gives me enough height that I don't have the wheels poking into the sleeping area. The torsion box is 1/4 ply on the bottom, then 1x4, then 3/8 inch ply for the floor. The 3/8 ply is plenty stiff to sleep on.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby synaps3 » Wed Jan 20, 2010 1:42 pm
Heck, I'm putting a 6.5x12 on a 4x8 frame.
I extended the tongue of the standard HF trailer out an additional 3' to accomplish this. I also flipped the axle to drop the height by about 6". Both mods are necessary for such a large overhang, or the trailer would jacknife at any turn, or might be "tippy." I haven't hit any issues whatsoever so far. I might not even use a substructure below the floor; 5/8" ply seems to be holding the edges quite well at this point.
-- Dave
Build log: here
synaps3
Images: 254
Postby whitefishpoint » Sat Jan 23, 2010 6:36 pm
Hey! where did you get those moon caps? Are those on the standard HF 12" wheels?
wannabefree wrote:My 5x10, on a 4x8 HF frame:
whitefishpoint
