Moderator: 2bits
eamarquardt wrote:And I thought my frame was strong.
I think you beat me!
I like the shape of your tear. I think I'll try and get closer to your shape. I'm gonna keep the vertical front to maximize interior floor space but I like tucking in the rear end a bit. Here's my current mock up:
Where the two horizontal blue tape stripes end will be the cabin's rear bulkhead with about a 14 inch storage space with a door on each side. I'll have a 20 gallon water tank , the battery, and room for chairs and other stuff so I don't have to store/carry stuff in the cabin when traveling. The galley will have a small r/v range/oven and a 3 way reefer (on hand) installed.
What is "lattice strip" and where did you get it. I used sched 125 pvc pipe but I like your technique for marking the curve with spray paint.
Looking good.
Cheers,
Gus
starleen2 wrote:I know you probably thought of this - but I have to ask - where is the safety margin in case a cable fails when towing? It sure would be a great sparkler if that should happen at highway speed - you may want to add some safety pins when in the Up position
Miriam C. wrote::applause: Watching this one. Love the raise/lower floor. Do you have an idea of what a frame like this would cost?
Shadow Catcher wrote:Got an idea of the weight so far? Looks interesting.
