glass beads as washers... I may be in for trouble
This is where the gals can have their very own discussions...
Postby Siouxgirl2 » Sun Apr 18, 2010 11:49 pm
Well since I was sick anyway, I drilled and screwed my headliner in. I don't like drilling metal (those metal shavings hurt).
My girly side may hurt me in the long run. I'm using beautiful decorative green pearly glass beads as washers behind my screws and they may not hold up to road vibration (they look awesome) so I may have to redo in the future with hand painted metal washers. We'll see. Since I had to demo and start over I thought I'd give an update about where I am in the process of my little tear.
Loyal
Siouxgirl2
Images: 69
Postby afreegreek » Mon Apr 19, 2010 12:31 am
all you need is some metal tube cut to be a little longer than the bead placed in the hole of the bead. that way the screw applies the pressure on the tube and not the bead. but I don't think you'll have any problem the way you have them now.. if they didn't break tightening up the screw, road vibration probably won't do it either. great idea BTW.. :D
afreegreek
Postby doris s. » Tue Apr 20, 2010 9:24 pm
Sounds beautiful! Great idea. I also like painted washer idea too!
Doris
doris s.
Images: 32
Postby Miriam C. » Tue Apr 20, 2010 10:34 pm
:pictures: :pictures: :pictures: Sounds really lovely. I am with the metal tube idea. They are more likely to come out than break the beads. :thumbsup:
http://www.bpfittings.co.uk/pc/Fold-Ove ... -c3916.htm
If you google screw cups and caps you will find different suggestions.
Postby Siouxgirl2 » Tue Apr 20, 2010 10:48 pm
Yeah, the metal tube idea is a great one... wish I'd thought of it but the beads didn't break. I did, however, use a few metal ones as temporary for areas I needed the strength with the idea as the wood molds better I would switch them to the beaded ones as well. I am hoping they last as I sealed each screw hole.
I may try to post a few pictures tonight if I get a chance of the headliner (I haven't put the sidewalls in yet because the frame isn't square so I have to do a few more adjustments before putting the sidewalls in.
Today I made a little decorative detail that I will add later on to make her have a little personal touch (more on that little thing later). :R
I have a hard time getting time on the computer to download pictures and the build is slow going with a little one (and I'm sick right now too).
I hopefully will get a few up soon. Thanks all!
Siouxgirl2
Images: 69
Postby Siouxgirl2 » Tue Apr 20, 2010 10:49 pm
PS. I'd never heard of screw caps... cool concept.
Siouxgirl2
Images: 69
Postby Miriam C. » Tue Apr 20, 2010 10:56 pm
Being sick with a little one is a big bummer. Be praying for you!
Postby Siouxgirl2 » Wed Apr 21, 2010 12:43 am
Thanks Aunti M!!
I posted pics in my album and hopefully embedded these two here.
Siouxgirl2
Images: 69
Postby Eunice » Wed Apr 21, 2010 10:33 am
Those look really nice! I like it
Eunice
former director
Jefferson State Chapter
TearJerkersImage
Eunice
Jefferson State Tearjerker
Images: 109
Postby Miriam C. » Wed Apr 21, 2010 10:51 am
:applause: :thumbsup: Very Nice!
I fixed the links for you. If you click on edit you can see the tags on the front and end. Trick is to highlight and click on IMG or click on img, paste and then img again. ;)
Postby S. Heisley » Wed Apr 21, 2010 10:59 am
That's a lovely detail that required considerable precision! :applause: It looks like you're doing a beautiful job. Hope you and your little one are well soon! :)
Return to Lady Teardroppers
