jamwuis
...not sure when to apply the CPES and whether I can apply it to the areas that will receive the glue or not.
maud'Dib
did you apply it before you glued the pieces together? Does the glue stick?
jamwius wrote:Your rebuild looks great. You mentioned that you applied CPES before assembly...did you apply it before you glued the pieces together? Does the glue stick? I am trying to plan ahead but not sure when to apply the CPES and whether I can apply it to the areas that will receive the glue or not. Any help would be great. I hope mine will turn out as nice as yours is.
John
Classic Finn wrote:Eric "Finntastic" work your doing.
I have a question for you. I looked in your gallery and found this pic. Can you tell me what the pipe is for on the towbar? Is that for a wheel or?
What size ball is that hitch for?
