surveytech wrote:Question for those who have used the radius corner windows in their tear.
Could you mount these without the clamp ring?
My wall are only 1/2" and the only rings I have found are for 3/4 and 1-1/2 inch walls.
Maybe drill through the face of the frame to mount them?
thanks,
Walter
Yes, it had and still does have a slight bow ('73 Chevelle). One reason I located the sun roof before I located the two cross frames for & aft of the sun roof. My roof is 1/8" ply and .062 alum. When I installed the inside ring with the factory screws it sucked the ply and alum up tight. From the outside, you can't hardly tell there is a bow. And it doesn't leak.Nitetimes wrote:Gage - Did your sunroof have a slight bow to it?.........
surveytech wrote:Jack.........how did you trim the windows on the inside if you didnt use the rings?
Guess I am just looking for options.
thanks!
Gage wrote:Yes, it had and still does have a slight bow ('73 Chevelle). One reason I located the sun roof before I located the two cross frames for & aft of the sun roof. My roof is 1/8" ply and .062 alum. When I installed the inside ring with the factory screws it sucked the ply and alum up tight. From the outside, you can't hardly tell there is a bow. And it doesn't leak.Nitetimes wrote:Gage - Did your sunroof have a slight bow to it?.........
Did that answer your question? Have a good day.
