Moderator: Sonetpro
deepmud wrote:And I always promote the other way Independent - really - we've posted opposite on the other threads.
BUT>
He's on number 5 and I have only built one trailer (and it's not a tear,either) from scratch. Mine's pretty old, and been on the road a LONG time, and I think it's the bomb....but he's right, leaf springs are simple, and tough. There is a reason they keep using that design under a million trailers and most new trucks - it works.
I built a custom, coil and link suspension on my 4x4 off-road rig - and it's taken me at least an extra year to do it If I had gone with proven, simple leaf suspension it would have been much MUCH faster to build. That's something to consider too. A leaf spring will be really easy to set up.
You can even set up airbags on a leaf spring if you find it's too soft, or if it's too hard and pull a leaf, and use airbags to get it "just right".
But I still like the way a trailing arm swings up and away from a bump, plus the clearance benefits Boxcar mentions. I've pulled my trailer on some crazy trails in "freight mode" (the box is removable) and feel it's important to have supple suspension when dragging it over downed trees and such. If Off-Road means not on a road(not just a bumpy dirt road), trailing arms are great and I think worth the extra engineering they require.
