Shamelessly stolen from Andrew's design for the Grumman 2, I stretched it vertically to 5'. Inspiration for raised bed with storage under was from the "Chief" in the teardrops book.
Doing the math I have learned that 5x10x5 teardrop is roughly 200% as much interior volume and 160% as much wall, bulkhead, ceiling, etc surface as a 4x8x4. The reasons for 5x is if using birch plywood in 5x5 sheets the waste is minimal- similar to 4x when using 4x8 sheets. I really like the under-bed storage and partly inset wheel wells.
I stretched the profile up by 1'. Wheel/axle/fender was not stretched in the main profile view- but was over in the section view. I moved the bed to just over the wheel well box giving 3'3" of headroom and about 12" of storage depth under. Since I stretched it vertically some items are a bit out of proportion. The other changes were a first pass at shifting around the galley and cabin cabinets.
With the vertical stretch, the counter top can move back a little because the rearmost "bulge" in the back profile moves up. I'd like to play around to see if a pleasing rear profile can be designed where the counter top is right at the longest point.
All I have right now is a .pdf. If someone can turn it into an image that would be great.
Andrew's 5x10x4' Grumman 2 web page
My 5x10x5' Grumman 3 .pdf file in Google Doc's
