Cyclicpitcher wrote:.... Yes! I am having fun .....
Cheers!
CP
You might consider gluing the spars to the skin while its flat on the ground. Then you can bend the roof skin to the walls and the spars are already in place.
Cyclicpitcher wrote:That would be the best way to do it in a Jayco Factory setting where you have plently of skilled hands and some professional cutting tools.
bdosborn wrote:You might consider gluing the spars to the skin while its flat on the ground. Then you can bend the roof skin to the walls and the spars are already in place.
