sdakotadoug wrote:Do I run the uninteruped wood (not the plywood) the long way and the interuped wood the short way or the other way around
Xanthoman wrote:I realize this is old but I’m case anyone happened on the question again...Torsion boxes are so named, I believe, because they resist torsion and remain planar and true without warping in any direction. As far as orientation of spliced pieces it would make most sense to put the continuous running length along the axis with the greatest bending moment (longest span typically). However, in a well made torsion box the joints are very tight and the skins hold the joints together and “see”, as mentioned previously by another, only a space separating the skins increasing the geometric inertia. The most important elements to remember on any composite structure such as torsion boxes or their single stringer counterpart, the I-beam, is that the web takes shear forces and the skins or flanges take the tension and compression forces. This only remains true as long as the interface between the flange and web is secured appropriately. So, make sure the skins are well adhered and it should technically be acceptable to have all sorts of gaps in the torsion spacer system. Admittedly, the unconnected points would be weak points where the skins could buckle if put under compression. So, in short, it shouldn’t matter your direction of continuity, but if there are gaps they should be on your tension side of the box as they have less effect on failure on that side of the system.
