sid wrote:I had talked to them before and they said it was a "virgin" material...(ha, okay, here come the jokes...) and you could not use a glue with it. I'm very intrigued with this stuff and want to see the possibilties.
sid n side
The GOOP is, well for lack of a better word, malleable so it seals and sticks without breaking when put between aluminum and the PolyMax
gman wrote:So have you tried welding it togeather? Use a solder tip on a propane torch or an electric woodburner.
Slayer wrote:I'm starting to think that all this stuff is good for is templates.
