Nitetimes wrote:That flange not being there wouldn't have changed the length of the spindle. All the ones I used were about the same length whether they had the flange or not.
At least, the clearance between the inside fender wall and the tire is no longer an issue. I have lots of room to spare now.
rooster wrote:Cracker and all, I would like to use a torsion style axle on my next build. Cracker is using Dexter brand, and what I can see it does not adjust up or down. Steve in his c/d shows a torsion axle that is and runs across to the other side and is adjustable, what brand it is I don't know. Why is one brand better than another? What is the best place to get one or the other?
Jim,
Mark Mckeeman wrote:At least, the clearance between the inside fender wall and the tire is no longer an issue. I have lots of room to spare now.
Dale,
You may want to consider using the brake flange to mount your fender. I've seen pictures here somewhere of a builder who did it that way. You can get a nice close fender to tire clearance that way since the fender moves up and down with the suspension. No need to fuss with inserts/bolts through the body either.
Just a thought,
Mark
Users browsing this forum: No registered users and 35 guests
