Wolffarmer wrote:Jess
I just read back to last year and saw you are having problems with your foam being to soft. I also had that problem. My fat ....... body would just sink into the foam and then i was sleeping on wood in a foam lined hole and very hard to move about. So this year I replace my foam with this.
Nice foam
I used the 5 inch thick but only enough for the upper 2 thirds of the bed. Leaving my feet on my old cheap crap foam. This is working much better for me even if it is now a bit to hard but it is not to bad. I slept in it for 10 days during Burning Man this summer. I would say that it is a bit hard, there is one that is not as hard. I used the 5 inch stuff, I could probably use 3 inch and not tell the difference, leaving a bit for a soft 1 inch foam, or just live with it.
I am 5 foot 9 inch tall and weigh 280.
Laying on the foam I doubt if I sink in more than one 1 inch, probably less, setting on it I don't go down over 1/2 way, this stuff is firm. So firm they could barely compress it even a little bit for shipping. That box looked like it was about explode.
So if you go this rout take that in to account. And my feet/legs don't know they are getting the cheap stuff.
Randy
S. Heisley wrote:First of all, congratulations on your new-to-you home! It will probably keep you pretty busy for a while.
On your trailer, please recognize that the CPES is only as good as it is able to sink into the wood and you probably know that those cracks need a good filler as well. Some sort of epoxy filler might be best. The Rot Doc sells 'Fillit' which has chopped fiberglass threads in it to help a little extra; but, there are probably others that could be used too. It's good that you were diligent and caught the problems early!
stomperxj wrote:Thanks Sharon- I used some automotive body filler over the cracks and splits. It worked ok but I think i'm going to have to do some dissasembly and really give it a good once over before i sell it.
Wolffarmer wrote:stomperxj wrote:Thanks Sharon- I used some automotive body filler over the cracks and splits. It worked ok but I think i'm going to have to do some dissasembly and really give it a good once over before i sell it.
You selling it? What will #2 be?
There is always a #2
Randy
jss06 wrote:Jess, this worked suprisingly well to add the extra length I needed to sleep comfortably without having to make the main body any longer. This made the bed area 6'6" long. I am 5'11" and 270 lbs. I had no problem stretching out comfortably.
The walls are only 6 inches in from the outter walls to give plenty of head room.
clintstuckless wrote:Beautiful build. Going to use alot of ideas from here
Could you upload some better pics of how you sealed the openings (ie. Doors and hatch)
Thanks
