small off-road trailer conversion...
Moderator: Sonetpro
Postby BC Dave » Tue Apr 05, 2011 1:17 am
86 slo-vo wrote:
S. Heisley wrote:Oh, good! Now, you have an escape door. :applause: "Mama" Sharon was worried about you before. You could even add a removable framed screen to that little door area, so you could get additional fresh air inside. Now, it is definitely camp-able! :yes:
yea its deffinantly much nicer inside, im hopeing i can find a slider window to fit inside the door itself but the screen idea is good also i might have to look into that
speaking form some experiance camping in a 6X10 trailer solo and occasionally with some company; you will need air circulation and windows will help make it feel less clostrophobic; set them maybe high closer to the rear cause people do peak ... I have found that they sweat lots; the roof vent will help lots; but I think you'll need windows too ... looks like fun adn your totally laughing at $ 225...
happy trails BC Dave
BC Dave
Postby Endo » Tue Apr 05, 2011 6:49 am
I see vertical and horizontal movement in your hitch but did you provide for rotation when the trailer is off camber??
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby 86 slo-vo » Tue Apr 05, 2011 9:05 pm
Endo wrote:I see vertical and horizontal movement in your hitch but did you provide for rotation when the trailer is off camber??
im working on building a center link that can twist, just havent got it done yet
86 slo-vo
Postby Endo » Wed Apr 06, 2011 7:50 pm
86 slo-vo wrote:im working on building a center link that can twist, just havent got it done yet
Please post pics once it's done.
I have considered building one as well.
I would like to see what you come up with for a center link.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby 86 slo-vo » Fri Apr 08, 2011 11:36 pm
i got started on it earlier, ill post some pics tomorrow
86 slo-vo
Postby 86 slo-vo » Sat Apr 09, 2011 11:01 pm
alright got it finished up today, took it for a pretty brutal test and worked great.
i cut the center link and welded in some 2 inch round 1/4 plate with a 5/8's grade 8 bolt with a steel washer in between and 2 washers between the plate and the head of the bolt and the nut. i also welded the nut to make sure it cant loosen up.
for as light as this thing is i think it will be fine.
also finished up the wiring for the land power and added a new light inside that can be rotated all the way around to put the light where i need it
86 slo-vo
Postby 86 slo-vo » Sun Apr 10, 2011 8:03 pm
got alot more done today, built a swing around table on the tongue to grill off of or to use as another layer of storage for the trip there. its ugly as sin but it going to work well.
and the toolbox lid still opens with it towards the back so when im loaded down heading for the trails if i need in there i can still open it up.
also got started on the 12v wiring, added a nice little fuse panel and a little fan plus 2 12v auto plug adapters
volt gauge for the battery.
86 slo-vo
Postby 86 slo-vo » Thu Apr 21, 2011 9:57 pm
got the grill mounted the other day
got the trailer loaded up and ready to go.
checked the tongue weight :
its just about perfect, pulls nice smooth and straight.
and loaded up, for a long weekend trip there will be a bunch more in there
86 slo-vo
Postby jeprovo » Thu Apr 21, 2011 10:27 pm
Every time I read this build, I want to make a clone. It is such a great little trailer!!!
What infor do you have on the manufacturer of the trailer?
jeprovo
Images: 7
Postby 86 slo-vo » Fri Apr 22, 2011 6:26 am
jeprovo wrote:Every time I read this build, I want to make a clone. It is such a great little trailer!!!
thanks man not sure on the year but NOMANCO originally built the trailer, tag says its rated at 1500lb's thats about all i know
:lol:
86 slo-vo
Postby 86 slo-vo » Thu May 19, 2011 10:02 pm
heading out for another one night trip tommorow after work, except this time its me and the wife...we'll see how it goes :lol:
86 slo-vo
Postby jeprovo » Tue May 24, 2011 9:19 am
So, How did the trip go?
jeprovo
Images: 7
Postby 86 slo-vo » Tue May 24, 2011 12:05 pm
went pretty good.
left the campground and ran a few trails, was pretty cool because with all the rain there were several water crossings from the strip pits being so high.
had to pull the trailer through about 18" of water to get to the parking lot then on down after we dropped the trailer off went through one that made the 36's disapear for a second. went through fine with no troubles
and back at home
here's a few from the lake at the campground, dont make fun of my white legs :thefinger:
86 slo-vo
Postby 86 slo-vo » Sun Aug 07, 2011 4:42 pm
its been a while since ive updated this, ive actually been looking for a new camper so this one is for sale. my second daughter is due in october so i figure its tme to make something big enough for the family.
i did throw a window in and still have another to throw in this week for the other side.
86 slo-vo
Hey
Postby Jeeper92 » Sun Aug 07, 2011 5:51 pm
how long is it on the inside?
hw much are you asking?
Jeeper92
