Offroad Pop-up
Moderator: Sonetpro
Postby schaapveld4 » Wed Apr 27, 2011 3:35 pm
wow neat van, too bad they don't allow them here in the U S.
I would figure if the trailer isn't any taller or skinnier than your van you should be good to go.
very impressive workmanship!
-Matt
schaapveld4
Postby Woodstramp » Thu Apr 28, 2011 4:47 am
Thanks for the vehicle education. I like it. Looks like it'd be a good tow vehicle for your camper, if you don't tax that 2.8l with too much weight. :)
Woodstramp
Postby PhotoGuy » Tue May 03, 2011 9:18 pm
I like the trailer frame. van is really neat too.
Keep up the good work
PhotoGuy
Couple updates
Postby asorensen » Tue May 10, 2011 12:15 am
Well I hope I am finished the welding because I have started covering the thing!
Here are a couple of pictures showing where I am at now.
Here is the pop up and roof down:
And here is the pop up and roof up.
I have insulated the floor with 1 1/2 foam and covered it with 1/2' fir plywood. (glued and screwed)
I have been planning out the interior layout and I hope to start on that and the interior skin soon. You can see the trailer frame in the background as well as my messy shop!
Thanks for looking
Andy
asorensen
Images: 65
Postby iSpy » Wed May 18, 2011 11:09 am
Great frame work :thumbsup:
but have you ever thought of building a slide-out within your teardrop ?
Here are some thoughts for you ....
Left hand slide-out for bed to sit across the van
second slide-out for internal seating area and dual access kitchen locker
Spare wheel mounted on the rear barn doors
First slide-out for leg room in transverse bed.
The two wooden doors to the left of the seat allow for internal access to the kitchen locker. On the outside is a large door for external access to the same kitchen locker.
I have yet to see a teardrop with a slide-out ...... let alone TWO !!
Good luck with the build ..... I can't wait to see this finished. It will be a great engineering project.
:applause:
iSpy
RE: New Build
Postby mezmo » Wed May 18, 2011 11:54 pm
Hi asorenson,
Great build design! It will be very interesting to follow your
progress on it. Have you determined how you will tie it down/
attach it to the trailer? Also how do you plan to lift and support it
when you demount it from the trailer? Something similar to the
pick-up camper jacks/supports? I'm sure you must have some
interesting takes on both matters - just surmising from all your
great work results so far!
An aside for iSpy:
Nice rig you have there. Did you build it out from a CT or is is a
CT manufacturer's design?
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby asorensen » Sun Jun 05, 2011 12:44 am
Thanks for all of the responses. I like the popouts iSpy!
My plan for attaching to the trailer I have adopted from the pickup camper crew.
I think that the turnbuckles that they use to attach them to their trucks would work fine for my needs.
Something like this: Image
I willing be making my own jacks for the four corners.
If you look at the pics closely you can see the welded tabs to accept the jacks.
Well moving along a bit slower than I would have hoped. I was away for 10 days completing my Canadian Ranger DP1 training.
Curious? Look here:http://www.army.forces.gc.ca/land-terre/cr-rc/index-eng.asp.
I have finally got the parts for the trailer so I will be working on getting it rolling in the next little bit.
In the meanwhile I have gotten to the fun part of the actual camper unit and I have a few pictures to show my progress.
Putting the first panels on.
I glued them with construction adhesive screws will be added later for window trim and whatnot.
Cross bracing till the glue dries overnight.
Window and door cutout.
Getting a little extra help!
The loft area.
Testing out the benches.
More updates to come soon. I am trying to get this thing done for trip down the coast(Vancouver Island to California) for this summer!
Thanks for looking.
Andy
asorensen
Images: 65
Postby jss06 » Sun Jun 05, 2011 5:34 am
That's coming together really nice.
jss06
Palladium Donating Member
Postby titanpat57 » Sun Jun 05, 2011 12:42 pm
Your son's look is priceless..great build...awesome job!!
titanpat57
Images: 139
Postby oregonguy » Mon Jun 06, 2011 10:28 am
I Love this build...Great Job! I'd like to make a full Aluminum frame trailer myself one of these days, and this one is very inspiring. :thumbsup:
Check out our Website: www.oregontrailer.net
oregonguy
Images: 48
Postby asorensen » Mon Jun 13, 2011 1:31 am
A couple of quick updates.
I have got the roof cap completed except for the vent and trim. Looking at the pictures I am definitely noticing a lack of trim.
I have also started some wiring.
Here is a picture on the inside looking up:
I have mocked up the table and I am fairly happy with it.
The front support is a scrap that will be replaced so no fear on it being out of plumb and all that.
The table has as its rear support a hinged section that extends to form the rear section of bed. Kind of hard to explain but it works!
Here is a picture:
Also in that picture you may notice my copper pipe that I fought with. Notice the burn mark on the wood!
As well as on the rear corner is one of the four jacks that I made for putting the camper on and off of the trailer.
These are not for leveling but are removed during normal usage.
Jack detail:
I am putting in pretty long hours on this thing.
I am still, naively, hoping to be done for July second. I hope it doesn't kill me!
Andy
asorensen
Images: 65
Postby droid_ca » Mon Jun 13, 2011 2:07 am
this one is coming along really well I love the loft I might need to borrow that idea I like your attention to detail :thumbsup: :applause: :thumbsup: :applause:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby asorensen » Sat Jun 25, 2011 11:58 pm
A couple of quick updates with pictures.
I am flying along. All of the wiring is done so that I could start covering the exterior.
All of the upper exterior walls are covered with FRP now and I am finished the two lower sides as well.
I flipped the trailer over on its side to do the two sides to get gravity working with me. I added whatever I had handy to the top to get it as flat as possible. Here are a couple pictures:
You can see I have got a real good mess going on at this point! if you can believe it I still plan on being finished for July 2. We will see.
These jacks that I made really helped facilitate actually getting it down.
The flipping it over was fairly easy it is not as heavy as I thought it was although I have stripped most of the cabinet work to put the finish on it all
Not that exciting really but in the next couple days it is all going to start coming together.
Andy
asorensen
Images: 65
Postby parnold » Sun Jun 26, 2011 10:55 am
:thumbsup: :thumbsup:
It is looking great!
I'm really enjoying following this one.
parnold
Images: 302
Postby S. Heisley » Sun Jun 26, 2011 11:05 am
Andy,
You're doing a great job on your build and I think you're going to be really happy with it. Thanks for sharing. :thumbsup: :applause:
